Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Version 5.1 doesn't work in windows10, but version 5.0 does |
| Print at Sep 25, 2026, 9:26:28 PM |
| Posted by Puybaret at Feb 2, 2016, 5:16:19 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does After a request to the company that issued the certificate used to signed Sweet Home 3D, it seems the problem could be bound to the fact that this certificate uses SHA-1 and not SHA-2. As said previously, this doesn't make the program corrupted though. I'm going to request a SHA-2 certificate that I'll use to sign the next version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stefbu at Feb 3, 2016, 4:43:14 PM |
Re:
Version 5.1 doesn't work in windows10, but version 5.0 does same problem even with version 5.2. Work only version 5 |
| Posted by Puybaret at Aug 4, 2017, 9:44:50 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does To those of you who had some problems with versions 5.1 or 5.2 last year, could you test again whether Sweet Home 3D 5.2 still crashes, then try the behavior of the version 5.5 beta 11. If the Beta version doesn't crash anymore, that will mean that the issue in Java 8 will have been fixed. Thanks for your help and feedback! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 9:26:28 PM |
