Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: A work with Sweet Home 3D - V5.1 |
| Print at Sep 29, 2026, 6:00:13 AM | |
| Posted by kurucom at Jan 22, 2016, 1:32:09 PM |
A work with Sweet Home 3D - V5.1 Created with Sweet Home 3D , Rendered with Lumion 6 Pro ![]() |
| Posted by VeroniQ at Jan 27, 2016, 6:36:57 PM |
Re: A work with Sweet Home 3D - V5.1 Well done. We can even feel the sun's heat. |
| Posted by santbose at Jan 28, 2016, 6:09:57 AM |
Re: A work with Sweet Home 3D - V5.1 Can you please explain how you rendered in Lumion. Because as far as I know lumion accepts only collada or skp models. |
| Posted by mazoola at Jan 28, 2016, 7:05:09 AM |
Re: A work with Sweet Home 3D - V5.1 Evidently it also accepts OBJ models. See this comment and this comment for another user's Lumion experience and workflow. |
| Posted by kurucom at Jan 30, 2016, 8:29:11 AM |
Re: A work with Sweet Home 3D - V5.1 Thank your very much VeroniQ.... Lumion accept OBJ format also santbose.... |
| Posted by kurucom at Jan 30, 2016, 8:37:12 AM |
Re: A work with Sweet Home 3D - V5.1 And here you can find the video of this project https://youtu.be/NlJga0rhMeg |
| Posted by Puybaret at Jan 30, 2016, 9:19:34 AM |
Re: A work with Sweet Home 3D - V5.1 Very nice indeed How long did Lumion take to generate this video? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kurucom at Jan 30, 2016, 9:29:35 AM |
Re: A work with Sweet Home 3D - V5.1 Around 2 hours for video Around 1 min for each picture Lumions render speed is ultimate.... |
| Posted by hansmex at Jan 30, 2016, 10:02:33 AM |
Re: A work with Sweet Home 3D - V5.1 And at €3.000 ex VAT, so is the price! ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by anhmax at Jan 30, 2016, 11:41:54 AM |
Re: A work with Sweet Home 3D - V5.1 very nice. I'm trying to learn to use this soft. Is the free version of Lumion can do this? ---------------------------------------- My channel: https://www.youtube.com/channel/UCM1mqUjGRtD4uCXX5qzgG3w |
| Posted by kurucom at Jan 30, 2016, 12:41:37 PM |
Re: A work with Sweet Home 3D - V5.1 anhmax yes free version is also do this but with watermark. Puybaret I paid € 1.999,- Please note: Lumion for inside rendering is very bad. I recommend use Sweet Home 3D instead of Lumion for inside rendering. |
| Posted by anhmax at Jan 31, 2016, 4:36:35 AM |
Re: A work with Sweet Home 3D - V5.1 I tried to export my OBJ file to Lumion. The render time is impressive. It takes less than 1 minute to render a picture. I'll try to render interior soon. SH3D Lumion ![]() ---------------------------------------- My channel: https://www.youtube.com/channel/UCM1mqUjGRtD4uCXX5qzgG3w |
| Posted by valpo74 at Mar 4, 2016, 11:13:44 PM |
Re: A work with Sweet Home 3D - V5.1 but how can i use a sh3d model or documente in lumion??? |
| Posted by mazoola at Mar 5, 2016, 3:09:00 AM |
Re: A work with Sweet Home 3D - V5.1 If you read back through earlier comments on this post, you'll see the Lumion users create the model in SH3D and then export it in OBJ format. (Since light sources don't export, you'll have to create those within Lumion -- but you'd probably want to, anyway, as most external renderers give you access to a wider range of light types than are currently supported by SH3D.) In theory, you can use this workflow with virtually any major ray-tracing or rendering application. |
Current timezone is GMT Sep 29, 2026, 6:00:13 AM |
