Print at Aug 12, 2026, 10:12:53 PM View all posts in this thread on one page
Posted by michjsear at Jan 29, 2016, 6:55:38 PM
Display Area not working
I just began using SH3D and have a question. Some rooms have a triangular plane that is visible from certain angles while viewing in 3D mode. Puybaret suggested I toggle off the "display ceiling"; this solved the appearance of these triangular planes. However, now, the area is displayed in these rooms...even when the "display area" is unchecked. Any ideas?
Posted by hansmex at Jan 30, 2016, 7:47:55 AM
Re: Display Area not working
Most probably there are two rooms on top of each other.
Posted by Puybaret at Jan 30, 2016, 9:18:04 AM
If you want to select the room which is below to remove it, you could right click in the room area and choose the room you want in the Select object menu available in the contextual menu.
