Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Possible to move an entire floor to align with another floor? |
| Print at Sep 26, 2026, 9:57:56 AM | |
| Posted by joshuairl at Feb 5, 2016, 12:16:13 PM |
Possible to move an entire floor to align with another floor? I'm having a problem now that I have my floors drawn that they aren't aligned in 3D space. https://www.dropbox.com/s/dsl0oc4weucmmps/Scr...02-05%2007.12.19.png?dl=0 I read through the instructions but can't seem to find anything, unless it's supposed to be a feature of a plugin that isn't installed or if it's supposed to be something within the base software? I'm new here, sorry if this isn't the right place to ask! I'm using latest version from the Mac AppStore FYI. Thanks in advance! - Josh |
| Posted by okh at Feb 5, 2016, 8:27:42 PM |
Re: Possible to move an entire floor to align with another floor? Automatically, not as far as I know. Usually it is better to copy the outer walls between levels so they inherit the same co-ordinates. If you want to move (several walls/rooms/models), you should try out the Advanced Editing Plugin. However, it looks as if your walls are not the same dimensions, so just moving them, may not be sufficient. In that case it might be easier to delete everything on level 2 and just copy everything from level 1. May be easier than modifying each wall... ok |
Current timezone is GMT Sep 26, 2026, 9:57:56 AM |
