Print at Sep 25, 2026, 10:56:36 AM
Posted by Wmatilda at Feb 13, 2016, 9:39:15 PM
How to make a horizontal tube
Hi all,
Please Help!! I'm desperate to know how to make a horizontal pipe/tube?
Thanks in advance..
Posted by okh at Feb 14, 2016, 7:01:45 PM
Re: How to make a horizontal tube
Import the cylinder from the free models page - rotate to horizontal during import (green arrows). Scale to correct size. ok
Posted by Wmatilda at Feb 20, 2016, 1:17:04 PM
Thanks for your help. How can I make this cylinder hollow?
Posted by okh at Feb 20, 2016, 2:53:54 PM
Well, it is hollow already... but if you want to open the ends you can set top and bottom to invisible (requires newest 5.2) - but as the inside has not texture - it may not give the effect you want.
Which means you are probably better off trying the cylinder shared by Ceciliabr in thread 6462 - that should be open ended.
