Print at Sep 25, 2026, 10:16:04 AM
Posted by Tiso at Feb 15, 2016, 9:37:42 AM
Using light, how can I set ?
Hi there,
I have tried to set a light into a room, but I dont the same atmosphere as show in some picture of the website.
Is there a trick to do it?
Thanks
Posted by hansmex at Feb 15, 2016, 11:02:15 AM
Re: Using light, how can I set ?
It's difficult to give an advice without seeing any picture(s).
In general, if you want more or less realistic lighting of a room, you should:
- disable Add ceiling lights in the Create photo dialogue
- use large lights (e.g. 100x100x100 cm) at a low strength to give a basic light level in the room
- use smaller accent lights to indicate other light sources
- experiment, experiment, experiment.
Posted by Tiso at Feb 15, 2016, 2:52:15 PM
Thank you for your quick replay, but I don't see any "add ceiling light" in the create photo dialog box.
Posted by SnakeGB at Feb 15, 2016, 8:50:10 PM
move the quality slider to best then it will show add ceiling loght check box
