Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Cant start sh3d after plugin install (linux) |
| Print at Sep 29, 2026, 12:43:54 PM |
| Posted by somuchfun at Feb 17, 2016, 7:16:04 PM |
Cant start sh3d after plugin install (linux) Linux OS: Exception in thread "AWT-EventQueue-0" java.lang.UnsupportedClassVersionError: sh3d_plugin/AdvancedSettings_PhotoRendering : Unsupported major.minor version 52.0 I've tried re-exploding the sh3d.tar but I still get that error. Where do plugins get installed so I can remove the offending one? Thanks |
| Posted by AeowynFraser at Feb 17, 2016, 11:53:04 PM |
Re: Cant start sh3d after plugin install (linux) I too am having trouble opening my house after installing the update. I keep getting the following (this is just a small part of the error message I'm getting): Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000017dd1545 Exception Note: EXC_CORPSE_NOTIFY For a copy of the complete error message: http://www.mediafire.com/view/7e81lx219sgsx0x/Process.docx I'm on an iMac. ![]() If this is something that's needed to know, I've also updated my Java after I first realized I was having trouble opening my file. ---------------------------------------- ![]() |
| Posted by Puybaret at Feb 18, 2016, 12:27:40 AM |
Re: Cant start sh3d after plugin install (linux) Somuchfun, the error you report is about an incompatibility of the plugin with the Java version you use. To remove the plug-in, please read the end of the user's guide. AeowynFraser, I don't think your problem is bound to plug-ins. Could you check if the problem happens with the previous version too? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AeowynFraser at Feb 18, 2016, 12:38:02 AM |
Re: Cant start sh3d after plugin install (linux) Thank you for the reply, Puybaret. I downloaded the older version and opened that version, but when I tried to open my file I got this error message: It is the same type of message I'd gotten before unfortunately. ---------------------------------------- ![]() |
| Posted by AeowynFraser at Feb 18, 2016, 12:45:00 AM |
Re: Cant start sh3d after plugin install (linux) I just realized that I "highjacked" somuchfun's topic and I'm so sorry. ---------------------------------------- ![]() |
| Posted by somuchfun at Feb 18, 2016, 1:30:41 AM |
Re: Cant start sh3d after plugin install (linux) thanks! That did it...i was searching for the wrong file. |
| Posted by 60secs at Jun 10, 2016, 1:58:01 PM |
Re: Cant start sh3d after plugin install (linux) thanks! That did it...i was searching for the wrong file. Did you find the solution? I have the same problem after installing some rendering plugins on Yosemite, I'm getting this message ![]() I reinstalled sh3d 5.2, updated java to v.8 update 91 I even installed the older version of sh3d 5.1 as Puybaret advised, nothing seems to work for me. Please share your experience. |
| Posted by Puybaret at Jun 10, 2016, 3:29:16 PM |
Re: Cant start sh3d after plugin install (linux) I guess you use an old version of this plug-in with the free Mac OS X installer version which uses Java 6 whatever more recent Java version you installed. Remove the plug-in you installed (choose Go > Go to folder in the Finder and copy paste the folder name ~/Library/Application Support/eTeks/Sweet Home 3D/plugins) then try the latest version of that plug-in. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by 60secs at Jun 13, 2016, 9:38:37 AM |
Re: Cant start sh3d after plugin install (linux) There is no eTeks folder in application support. it seems that I uninstalled that plug-in already, but sh3d still doesn't work. when I try to install latest version which you provided, again same massage appears. I downgraded to java 6 but doesn't matter. I think some file stuck somewhere which prevents sh3d from running, |
| Posted by 60secs at Jun 13, 2016, 10:28:19 AM |
Re: Cant start sh3d after plugin install (linux) P.S. I don't need this plug-in at all, i just need my sh3d back :) |
Current timezone is GMT Sep 29, 2026, 12:43:54 PM |
