Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Inability to install Sweet Home 3D 5.2 on Windows Vista |
| Print at Sep 27, 2026, 5:20:32 PM | |
| Posted by enkonyito at Feb 20, 2016, 4:13:39 PM |
Inability to install Sweet Home 3D 5.2 on Windows Vista When I do right click "Run as administrator" on SweetHome3D-5.2-windows.exe, nothing happens. So I can not use the SweetHome3D.l4j.ini file. With SweetHome3D-5.1-windows.exe, the installation window opens. ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Feb 20, 2016, 5:02:12 PM |
Re: Inability to install Sweet Home 3D 5.2 on Windows Vista I hope you'll find the reason why it doesn't work for you, just because I don't have any PC with Vista to test the installer. I tested it on Windows XP, 8.1 and 10. But why do you need to run the installer with Run as administrator menu item? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Feb 21, 2016, 11:00:20 PM |
Re: Inability to install Sweet Home 3D 5.2 on Windows Vista Double-clicking does not work, I tested the right click... I have not had any problems with the beta versions of the installer. The SweetHome3D.l4j.ini file was useful to set preference the rendering properties. As I use the portable version instead, I should find another solution. ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 27, 2026, 5:20:32 PM |
