Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: system slower since update |
| Print at Sep 29, 2026, 2:58:00 PM | |
| Posted by hobbyrv at Mar 1, 2016, 9:22:28 AM |
system slower since update Since the update to 5.2 and 1.6 the system is a lot slower. I have to wait quite a time after importing or changing objects. Is there a way to speed it up? |
| Posted by Puybaret at Mar 1, 2016, 3:01:37 PM |
Re: system slower since update The changes in the program shouldn't slow it down. Did you reinstall Sweet Home 3D 5.1 to check that it really runs faster with that version? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mazoola at Mar 5, 2016, 3:39:57 AM |
Re: system slower since update @hobbyrv If you haven't yet, restart your system. After upgrading to 5.2a, I ran into a number of issues -- including inordinate delays after modifying an object (or simply opening an object to modify, and then canceling out of the action). I also ran into some rendering oddities. Long story short, after spending a night running tests, timing processes, and making notes towards opening a problem report, I nded up rebotting my system for other reasons... and discovered all of my problems had disappeared. I'd begun the day running SH3D 5.1, and as best I can guess, certain 5.1 libraries or modules must have been left open and therefore couldn't be updated until after the reload... |
Current timezone is GMT Sep 29, 2026, 2:58:00 PM |
