Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to start SH3D without recovery |
| Print at Aug 31, 2026, 11:03:36 PM | |
| Posted by SNAKE83 at Mar 4, 2016, 1:49:08 PM |
How to start SH3D without recovery Hi I have been using .jar version, once it crashed now when I am starting, it shows in title bar [Recovered] with 100% cpu and nothing happens, just freeze. How to force start without opening last project or automatic recovery ? OSX 10.11.3 SH3D 5.2 console output |
| Posted by Puybaret at Mar 5, 2016, 10:00:48 AM |
Re: How to start SH3D without recovery The files that Sweet Home 3D tries to recover at its start have a .recovered extension and are stored in the C:\Users\userrecovery subfolder that you can find in a private folder that depends on your system: - C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D under Windows Vista / 7/8/10, - C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D under Windows XP and previous versions of Windows, - Library/Application Support/eTeks/Sweet Home 3D of your user folder under Mac OS X, - Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D of your user folder under Mac OS X Mac App Version, - .eteks/sweethome3d of your user folder under Linux and other Unix, - data of the folder that contains Sweet Home 3D applications under the portable version. Under Mac OS X, to ensure you pick the right eTeks folder, you can open a new window in the Finder, select Go > Go To Folder menu item (cmd + Shift + G shortcut), and enter the folder ~/Library/Application Support or ~/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D. If you don't mind, please send me the .recovered file that caused your issue. When a recovered candidate file can't be opened, it's supposed to be renamed with a .unrecoverable extension to avoid the loop bug you encountered. If I can find how to detect the problem in your file, I'll fix this mechanism. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 31, 2026, 11:03:36 PM |
