Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: java issues on OS 10.11.3 (El Capitan) |
| Print at Sep 29, 2026, 6:00:10 AM | |
| Posted by maineiac at Mar 5, 2016, 11:13:00 AM |
java issues on OS 10.11.3 (El Capitan) Hi there I've got java installed but on startup Sweet Home 3D is unable to locate it... /Applications/SweetHome/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit; No Java runtime present, requesting install. logout this is the java version I've got installed: java -version java version "1.8.0_71" Java(TM) SE Runtime Environment (build 1.8.0_71-b15) Java HotSpot(TM) 64-Bit Server VM (build 25.71-b15, mixed mode) Where does Sweet Home 3D try to find java? I'm pretty sure I just have to either adapt some Sweet Home startup script or add an additional java path somewhere... Any suggestions? Best regards, Alex |
| Posted by Puybaret at Mar 6, 2016, 12:44:39 AM |
Re: java issues on OS 10.11.3 (El Capitan) At this time, the installer version requires to install Java 6 to run under El Capitan. Or if you absolutely want to use Java 8, you can run the Java Web Start version of Sweet Home 3D or its executable Jar version (to run these two versions, the first time, you should click on the downloaded file while maintaining the ctrl key pressed, and choose Open in the contextual menu that will appear). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by maineiac at Mar 6, 2016, 6:20:48 AM |
Re: java issues on OS 10.11.3 (El Capitan) Thanks Emmanuel! In that case I'd rather stick to java 8 (as 6 has some vulnerabilities) and will try to run the web start or the .jar Thanks! Alex |
Current timezone is GMT Sep 29, 2026, 6:00:10 AM |
