Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Join (or merge) 2 adjacent walls? |
| Print at Oct 7, 2026, 8:31:13 PM | |
| Posted by CCPT at Mar 5, 2016, 12:14:28 PM |
Join (or merge) 2 adjacent walls? Hi When I draw 2 or more walls in a single process, adjacent walls are drawn with a "join" between them: However if I draw the adjacent walls at different times they don't "join" together - and has a result if the 2 walls have different colors in 3d view we see a vertical stripe on the union off the 2 walls: Is it possible to "merge" these 2 walls? Thanks, CC |
| Posted by okh at Mar 5, 2016, 3:18:00 PM |
Re: Join (or merge) 2 adjacent walls? The #4 Advanced plan editing plug-in available from the SH3D SF plug-ins allows you to connect / join two selected walls (that run in the 'same' direction, when they are selected in the correct order). ok |
| Posted by CCPT at Mar 5, 2016, 10:22:19 PM |
Re: Join (or merge) 2 adjacent walls?Thank you - this plugin solved my issue. |
Current timezone is GMT Oct 7, 2026, 8:31:13 PM |
