Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to modify the light power of a group of lights |
| Print at Oct 6, 2026, 4:56:48 AM | |
| Posted by John37 at Mar 6, 2016, 9:52:43 PM |
How to modify the light power of a group of lights Is it possible to modify the light power of grouped lights? Or do I have to modify each light of the group individually? The Modify Furniture dialogue box doesn't seem to allow the light power of a group of lights to be modified |
| Posted by okh at Mar 6, 2016, 10:48:02 PM |
Re: How to modify the light power of a group of lights If it is the same model repeated in the plan, you can select several and edit their properties using Modify furniture. ok |
| Posted by John37 at Mar 7, 2016, 9:32:22 AM |
Re: How to modify the light power of a group of lights Thanks, ok, yes I know that, but if you have 20 light sources all having the same properties (e.g. having the same light power) that are grouped into 5 groups, it's not convenient to ungroup them before selecting them all. I'd like to be able to change the light power of all of them using the Modify furniture on the group of light sources without having to ungroup them. Is there a way to do this? |
| Posted by Puybaret at Mar 7, 2016, 10:30:10 AM |
Re: How to modify the light power of a group of lights In the furniture list, expand the groups and instead of selecting the groups themselves, add the lights of those groups to the selection by clicking on them while pressing Ctrl key under Windows / Linux or cmd key under Mac OS X. Then, you'll be able to change the light power with Furniture > Modify menu item. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by John37 at Mar 7, 2016, 10:54:19 PM |
Re: How to modify the light power of a group of lights Thank you, that's a good workaround. May I request an enhancement in the next release to enable the light power of the grouped lights to be changed directly, as a group? |
Current timezone is GMT Oct 6, 2026, 4:56:48 AM |
