Print at Oct 3, 2026, 12:55:47 AM
Posted by jon5 at Mar 7, 2016, 7:01:24 PM
Parellelize videorendering?
If I get it right the current videorendering is singlethreaded, correct?
Have you considered to parallelize the videorendering to cut down the rending time? I have not checked the code but maybe streams as mentioned on https://stackoverflow.com/questions/27558605/java-8-parallel-for-loop can be of help.
Posted by jon5 at Mar 7, 2016, 8:00:57 PM
Re: Parellelize videorendering?
I tried again and found that the two best settings keeps all of my cpu buzy so my question is only valid for the two fastest settings.
Posted by mazoola at Mar 9, 2016, 7:52:43 PM
@jon5
My understanding was that each 'bucket' in the rendering process was initiated as its own thread, with as many buckets running simultaneously as the PC has cores...
