Print at Sep 25, 2026, 11:02:17 PM
Posted by nougie2 at May 28, 2016, 8:20:35 AM
Error "Can't home home" for some homes in SweetHome3DOnline with Linux
Hello!
I use http://www.sweethome3d.com/SweetHome3DOnline.jsp regularly and without any issues in Windows, but occasionally I want to use it in Linux, and then I get the error "Can't home home" for some homes.
The weird thing is that for some homes I don't get this error in Linux, so they work great. But unfortunately for most of my homes I get this error (it seems saved versions of an original home generally get this error - but this is not always the case?)
My information: Linux Lubuntu 16.04, Firefox 45.0.2, openjdk version "1.8.0_03-Ubuntu" OpenJDK Runtime Environment (build 1.8.0_03-Ubuntu-8u77-b03-3ubuntu3-b03) OpenJDK 64-Bit Server VM (build 25.03-b03, mixed mode)
It would be nice to solve this problem since I really like this program and it's a pity I can't fully use it now... :) Thanks a lot in advance!!
Posted by Puybaret at May 28, 2016, 10:52:51 AM
Re: Error "Can't home home" for some homes in SweetHome3DOnline with Linux
Sorry for this issue. Did it happen just during the past 2 or 3 days, or even before?
By the way, I guess you meant "Can't save home" or "Can't read home" and not "Can't home home", right?
Posted by nougie2 at May 29, 2016, 6:42:43 PM
I am really sorry, I meant "Can't open home"... :) Can you maybe rename the title of this Thread?
This issue has happened in this month (only since then I (try to) use SweetHome3DOnline in Linux)
Posted by nougie2 at Jun 12, 2016, 9:04:52 AM
Dear Emmanuel, do you have an idea to solve this problem? I have been trying out, and it seems that when I save (again without any modifications) a file which was able to be opened in linux, the error will appear in Linux. Maybe this has something to do with overwriting while saving a file? Thanks a lot in advance.
Posted by Puybaret at Jun 12, 2016, 6:56:22 PM
As it's a problem with the Online version could you try on a computer with an other system?
