Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Files in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D |
| Print at Aug 31, 2026, 8:38:42 PM | |
| Posted by bradhouser at Jun 10, 2016, 10:54:02 AM |
Files in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D I have been through various versions of SH3D on my system. Most recently, I have had to use the webstart version after my video card died and was replaced with one that didn't support the installed version. While investigating a c: drive disk full problem, I noticed I have over 18 GB of stuff in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D. It all appears to be old, but I don't want to cause any problems with my setup. Can they safely be deleted? Thanks! |
| Posted by Puybaret at Jun 10, 2016, 11:37:08 AM |
Re: Files in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D This folder contains preferences, imported 3D models and textures, and temporary files. If you remove it, you'll lose imported data in Sweet Home 3D furniture and textures catalog. But you can remove the work and recovery subfolders without problem (it's probably them who take a lot of room). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 31, 2026, 8:38:42 PM |
