Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Export bugs |
| Print at Oct 4, 2026, 7:11:40 AM | |
| Posted by mazoola at Jul 1, 2016, 12:43:31 PM |
Export bugs Emmanuel - I've opened two tickets on the export issues I reported -- namely, incorrect illumination model exported and texture images resized on export. I've discovered the second problem also affects objects imported using the Furniture Library editor and saved in a .SH3F file, so the resizing may be a part of the import process. (At least, I've discovered it affects objects saved in the library in OBJ/MTL format. In examining furniture libraries exported from SH3D using the 'export imported furniture' [or whatever it's called; I'm currently writing from a machine w/out SH3D installed] command on the 'Furniture' menu, I see objects may be saved in either Lightwave or Collada format. What determines which format is chosen?) Thanks, maz |
| Posted by Puybaret at Jul 1, 2016, 2:02:08 PM |
Re: Export bugs Thanks for opening the tickets. I saw your issues but didn't test them yet. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mazoola at Jul 1, 2016, 4:11:49 PM |
Re: Export bugs I know: I always seem to forget to open a ticket... unless I'm on the receiving end, when I'm a real SOB about everything being properly documented. I figured I'd do it right this time. ![]() |
Current timezone is GMT Oct 4, 2026, 7:11:40 AM |
