Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome3D.l4j.ini in Linux |
| Print at Sep 27, 2026, 7:06:02 AM | |
| Posted by adlerhn at Jul 6, 2016, 11:17:49 AM |
SweetHome3D.l4j.ini in Linux For increasing the max memory, as well as HiDPI adjustments (http://www.sweethome3d.com/support/forum/viewthread_thread,5384_offset,10), Linux users are asked to modify the startup script, which is understandable. However, this script is part of the installed files, which should not be modified after install, and which will be lost after the next upgrade. Would it be possible to configure these flags somewhere else, such as in a SweetHome3D.l4j.ini file under ~/.eteks ? |
| Posted by Puybaret at Jul 6, 2016, 10:29:25 PM |
Re: SweetHome3D.l4j.ini in Linux This .ini file is a feature of launch4j which is used only under Windows. So this might be possible under other systems but it would require some development... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 7:06:02 AM |
