Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create photos at points of view - advanced options |
| Print at Sep 25, 2026, 2:32:19 PM | |
| Posted by adlerhn at Jul 6, 2016, 11:33:59 AM |
Create photos at points of view - advanced options First of all, thanks for developing this fantastic piece of software. It is not only very cool, but also really useful. I am using the "Create photos at points of view" option. However, this option misses some options that the "Create photo" menu has. In particular:
And specifically on the points of view:
I will check later where are points of view stored in the filesystem; maybe I can modify the files manually (faster than through the UI). |
| Posted by mazoola at Jul 6, 2016, 2:28:32 PM |
Re: Create photos at points of view - advanced options To overly complicate things , I'd like to see the stored point of view also include the visible/invisible status of all furniture objects (including light sources) in the plan. This would allow one to batch up a number of potentially time-consuming renders and fire them off at once, regardless of where within the plan they are located. Currently, one either is limited to a subset of renders illuminated by the same group of light sources at the same intensities, or each individual render may be needlessly prolonged by having to test for intersections with all light source used by any of the desired scenes.Variations on this theme might be "all furniture objects (including light sources and the intensity of each visible light source)," "all levels and furniture objects" or, if you really wanted to ruin Emmanuel's day, "all levels, walls, and furniture objects." |
Current timezone is GMT Sep 25, 2026, 2:32:19 PM |
