Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: only allow walls at 0, 45, 90, 135, 180, 225, 270, 315 and 360 degrees |
| Print at Oct 18, 2026, 5:57:20 PM | |
| Posted by rvwrvw at Jul 25, 2016, 4:20:40 PM |
only allow walls at 0, 45, 90, 135, 180, 225, 270, 315 and 360 degrees Hi all, could not find the answer in the forum yet (newby, sorry) but when splitting and connecting walls (I have the Advanced Editing plugin installed), the walls very easily move a little bit unintended. I have magnetism turned on, but is it also possible to force all walls to be/stay 90, 180, 270 and 360 (or also 45, 135, 225 and 315 degrees) instead of having them all move a few millimeters every time? |
| Posted by Miker777 at Jul 26, 2016, 6:36:49 PM |
Re: only allow walls at 0, 45, 90, 135, 180, 225, 270, 315 and 360 degrees Hi rvwrvw You may get slightly better results by turning magetism off when trying to move or rotate your walls, alternatively, on the tool bar near the centre of the screen are icons that allow you to flip or mirror a highlighted item also one that allows to to rotate to a angle, that you can set yourself. |
| Posted by Miker777 at Jul 26, 2016, 6:38:32 PM |
Re: only allow walls at 0, 45, 90, 135, 180, 225, 270, 315 and 360 degrees correction "allows you to rotate to an angle" |
Current timezone is GMT Oct 18, 2026, 5:57:20 PM |
