Print at Sep 29, 2026, 6:39:33 AM
Posted by saadjumani at Aug 3, 2016, 7:29:03 AM
confused   Compiling SH3D with my own 3D Models
Hello everyone,
I am trying to give my clients a a modified version of SH3D, with 3D models of THEIR products (furniture) instead of SH3D default library.
Since most people don't prefer to get into "technicalities" I would like it if they don't have to import a library manually every single time they install it on a new device. So is there a way to either compile SH3D with a different library set or at least a way to ship the compiled SH3D (JAR File produced after the I build it from XML in eclipse) in a way that it is ready to run out of the box. Also how do I remove the existing 3D models?
Thanks in advance.
Posted by dorin at Aug 30, 2016, 12:50:23 PM
Re: Compiling SH3D with my own 3D Models
I'm not a programmer but for something similar needs I modify the program itself. Under linux!
Go to SweetHome3D-5.2/lib/ and You will find Furniture.jar archive which have the basic furniture. Modify this or replace with Your own.
Another way is to make a install script to put all the pieces in the right place respectively the custom furniture, plugins, texture etc in the path: .eteks/sweethome3d/
Posted by saadjumani at Sep 3, 2016, 8:12:14 PM
Thanks for your input, I figured this out the day after I posted my question, but it was too late to then remove it from the threads (Tried to delete it cuz I also realised later the question was kinda useless as it has already been answered before :p )
Thanks anyways.
