Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: 2040 : Mars Two |
| Print at Oct 10, 2026, 9:02:18 AM |
| Posted by bdfd at Oct 2, 2016, 6:21:36 AM |
Re: 2040 : Mars Two Here technical specifications of habitation module v2. 1900 x 1400 in Q4 without R1.3.1 If a storm occurs (I saw the movie 'The martian'), an anti-tilt system is set up. 4 cables out of the fifth floor (light gray, base of roof) and will be planted in the ground (like harpoons) ... This module has five levels (with descent engines). 1st : Airlock and a rear cargo 2nd : technical part 3rd : living and sick bay 4th : bedrooms 5th : roof (upper airlock, antennas, parachutes, ...) It can support 11 people ! ![]() It is equipped with 4-wheel drive to adjust its position. ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by bdfd at Oct 3, 2016, 6:40:39 AM |
Re: 2040 : Mars Two D 188 : The D Day ! Departure begins... 1920 x 1024 in Q4 without R1.3.1 All 11 members of crew are aboard. Look at simply inside MRV v2 : 4 in cockpit and 7 under head (lying 45 °). side view The order to come in : The three first passengers in lower armchairs, The next four in upper armchairs, The two external astronauts in cockpit and finally The chief and the pilot in last (central location)... Red : air lock, Grey : Dashboard, Green : cockpit, Blue : 7 Passengers (2 lines of 3 + 4 at different height. Yellow : technical storage, Dark blue : life support, Purple (rear red) : toilets, Rose : technical part, Cyan : engines & tanks Brown : main thrusters ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Oct 3, 2016, 9:25:02 AM |
Re: 2040 : Mars Two Passengers must be impatient to land! Good idea to use transparency for such a small space ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Oct 3, 2016, 3:05:40 PM |
Re: 2040 : Mars Two A hot moment for the crew and 30 mn after the Space center on Earth... 1024 x 800 in Q4 without R1.3.1 Heat shield is gone, like MRV the temperature descents, parachutes are open ! 1920 x 1080 in Q4 without R1.3.1 ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by bdfd at Oct 4, 2016, 5:58:02 AM |
Re: 2040 : Mars Two Slowly crew arrives on martian ground... 1920 x 1080 in Q4 without R1.3.1 ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by MartinSK at Oct 4, 2016, 6:04:21 AM |
Re: 2040 : Mars Two Wow... "hot moment picture"...looks really really great... |
| Posted by bdfd at Oct 4, 2016, 9:22:01 AM |
Re: 2040 : Mars Two Touch Down ! 1920 x 1080 in Q4 without R1.3.1 "Hello Earth, Condor is on Mars ! " Quicky from Hermes... 30 mn later from Earth... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by VeroniQ at Oct 4, 2016, 3:08:43 PM |
Re: 2040 : Mars Two Hurrah! Is the whole crew alive? |
| Posted by bdfd at Oct 4, 2016, 7:34:36 PM |
Re: 2040 : Mars Two Yes, but some jerseys well sweat ! Here is the First interior view of this project. 1024 x 768 in Q4 without R1.3.1 Light is green, the second astronaut prepares his output from air lock... Their priorities : 1. Prepare Habitation module, 2. Install Solar modules, 3. Go out the rover to take all members of crew... ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by bdfd at Oct 5, 2016, 6:40:14 AM |
Re: 2040 : Mars Two Here spécifications of MRV. 1900 x 1400 in Q4 O.S.S. will be detailled later. ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Oct 10, 2026, 9:02:18 AM |
