Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How can I create a ramp? |
| Print at Oct 13, 2026, 5:03:50 PM | |
| Posted by JuanEDC at Sep 22, 2016, 3:48:33 AM |
How can I create a ramp? Hello, I'm doing an underground parking, so, somebody knows how can I create a ramp or a triangle to simulate the inclined road to the parking places?? Thank you for the help. |
| Posted by okh at Sep 22, 2016, 8:34:27 AM |
Re: How can I create a ramp? Use a triangle (or other shape) placed at the lower level - i.e. in the ground. There are several threads about this in the forum, but I cannot find them off hand. Good luck. ok |
| Posted by [email protected] at Oct 1, 2016, 1:08:24 AM |
Re: How can I create a ramp? Hello, I would suggest considering just using a wall, double clicking it and then choose the 'Sloping wall' option. Give it a thickness to represent the width of the ramp. Height start and end provide the slope desired. It worked out in a quick test I did. |
| Posted by Miker777 at Oct 1, 2016, 7:42:34 PM |
Re: How can I create a ramp? The triangle or shape and the wall would both work well, the wall has the advantage that it can be arced but the disadvantage that it has a minimum height, which may be higher than the floor. Mike |
| Posted by VeroniQ at Oct 4, 2016, 3:34:53 PM |
Re: How can I create a ramp? There is a ramp in the example 6 of the Gallery (made with a triangle, in the basement) |
| Posted by bdfd at Oct 4, 2016, 7:50:31 PM |
Re: How can I create a ramp? You can see one of my projects HERE There are three ramps at different levels... Shape, wall or triangle are the same thing, it's not easy to locate them. ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Oct 13, 2026, 5:03:50 PM |
