Print at Oct 3, 2026, 2:23:34 PM
Posts: 31   Pages: 4   [ Previous Page | 1 2 3 4 | Next Page ]
Posted by dorin at Dec 5, 2018, 6:46:31 PM
Re: Export HTML5 plug-in
I'am not sure but could be a problem of browser rather than coding.
Look at this answer
Posted by Puybaret at Dec 5, 2018, 8:51:56 PM
Thanks for trying to help Dorin, but your link points to problems in the Online version, not with the HTML5 viewer version.
Anyway, you're not wrong when your speak about browsers, because the viewer could also not work correctly on some browsers (even if I don't hope so).
boe666, the most helpful code is the one tested on a real web server with a real SH3D file. So please, upload your failing HTML5 code on a public web server with a SH3D file.
You could also use the very good JavaScript debuggers available in all modern browsers, and find what's wrong by yourself.
Posted by boe666 at Dec 6, 2018, 9:28:20 AM
ok. So I clean the code, and put all on this link:
http://smarted.pl/sh3d/viewHome.html#
As You can see - all object are selectable by code.
But not by the mouse.
Please check console.
Code below:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>View home with Sweet Home 3D HTML5 Viewer</title>
<!-- Copy the following scripts in your page header -->
<script type="text/javascript" src="lib/big.min.js"></script>
<script type="text/javascript" src="lib/gl-matrix-min.js"></script>
<script type="text/javascript" src="lib/jszip.min.js"></script>
<script type="text/javascript" src="lib/core.min.js"></script>
<script type="text/javascript" src="lib/geom.min.js"></script>
<script type="text/javascript" src="lib/stroke.min.js"></script>
<script type="text/javascript" src="lib/batik-svgpathparser.min.js"></script>
<script type="text/javascript" src="lib/jsXmlSaxParser.min.js"></script>
<script type="text/javascript" src="lib/triangulator.min.js"></script>
<script type="text/javascript" src="lib/viewmodel.min.js"></script>
<script type="text/javascript" src="lib/viewhome.min.js"></script>
<style type="text/css">
/* The class of components handled by the viewer */
.viewerComponent {
</style>
</head>
<body>
<div>
<!-- Copy the following canvas and components in your page, changing their size / texts and other values if needed -->
<table><tr><td style="margin-top:0px;">
<canvas id="viewerCanvas" class="viewerComponent" width="800" height="600"
style="background-color: #CCCCCC; border: 1px solid gray; outline:none" tabIndex="1"></canvas>
<div id="viewerProgressDiv" style="width: 400px; position: relative; top: -350px; left: 200px; background-color: rgba(128, 128, 128, 0.7); padding: 20px; border-radius: 25px">
<progress id="viewerProgress" class="viewerComponent" value="0" max="200" style="width: 400px"></progress>
<label id="viewerProgressLabel" class="viewerComponent" style="margin-top: 2px; display: block; margin-left: 10px"></label>
</div>
<div style="margin-top: -60px">
<input id="aerialView" class="viewerComponent" name="cameraType" type="radio" style="visibility: hidden;"/>
<label class="viewerComponent" for="aerialView" style="visibility: hidden;">Aerial view</label>
<input id="virtualVisit" class="viewerComponent" name="cameraType" type="radio" style="visibility: hidden;"/>
<label class="viewerComponent" for="virtualVisit" style="visibility: hidden;">Virtual visit</label>
<select id="levelsAndCameras" class="viewerComponent" style="visibility: hidden;"></select>
</div>
</div>
</td><td style="vertical-align:top;"><div id="PRitemlist" style="width:400px; margin-top:0px;></div>
</td></tr></table>
<div style="position: absolute; bottom: 5px; text-align: center; width: 95%; z-index: -1">
<a href="http://www.sweethome3d.com">Sweet Home 3D</a> HTML5 Viewer / Version 1.4 - Distributed under GNU General Public License
</div>
<!-- Copy the following script to view your home in the previous canvas -->
<script type="text/javascript">
var homeUrl = "test.zip";
var onerror = function(err) {
if (err == "No WebGL") {
alert("Sorry, your browser doesn't support WebGL.");
} else {
console.log(err.stack);
alert("Error: " + (err.message ? err.constructor.name + " " + err.message : err));
var onprogression = function(part, info, percentage) {
var progress = document.getElementById("viewerProgress");
if (part === HomeRecorder.READING_HOME) {
// Home loading is finished
progress.value = percentage * 100;
info = info.substring(info.lastIndexOf('/') + 1);
} else if (part === Node3D.READING_MODEL) {
// Models loading is finished
progress.value = 100 + percentage * 100;
if (percentage === 1) {
document.getElementById("viewerProgressDiv").style.visibility = "hidden";
setTimeout(myfunction,1000);
document.getElementById("viewerProgressLabel").innerHTML =
(percentage ? Math.floor(percentage * 100) + "% " : "") + part + " " + info;
var canvas = document.getElementsByTagName('canvas')[0];
var HPC = viewHome(canvas.id,
homeUrl,
onerror,
onprogression,
{roundsPerMinute: 0,
navigationPanel: "none",
aerialViewButtonId: "aerialView",
virtualVisitButtonId: "virtualVisit",
levelsAndCamerasListId: "levelsAndCameras",
activateCameraSwitchKey: true
function selectI(a)
var HOME = HPC.getHome();
var FURNITURES = HOME.getFurniture();
var itemSel = [FURNITURES[a]];
HOME.setSelectedItems(itemSel);
console.log(itemSel);
console.log("Selected by Link: ID:" + a +", name:"+itemSel[0].name);
function myfunction() {
var UP = HPC.getUserPreferences();
UP.setAerialViewCenteredOnSelectionEnabled(true);
var ITEMS = HOME.getSelectableViewableItems();
console.log("All items: ");
console.log(ITEMS);
console.log("All furnitures: ");
console.log(FURNITURES);
var tt = 'All FURNITURES:<br/>';
var i;
for (i = 0; i < FURNITURES.length; i++) {
tt += '<a href=\"#\" style=\"float:left;border:1px #000000 solid; padding:2px; margin:2px;\" onclick=\"selectI('+i+');\" >'+FURNITURES.name+'</a>';
document.getElementById("PRitemlist").innerHTML=tt;
canvas.addEventListener("mouseup", function (e) {
var rect = canvas.getBoundingClientRect;
var x = e.clientX ;//- e.layerX;
var y = e.clientY ;//- e.layerY;
console.log('mouse pointer:' + x + ', ' + y );
console.log("Finded objekt:");
var obj = HPC.getComponent3D().getClosestItemAt(x, y);
console.log("Finded objekt:"+obj);
</script>
</body>
</html>
Posted by boe666 at Dec 10, 2018, 10:03:48 AM
Can somebody help ?
Posted by boe666 at Dec 11, 2018, 8:02:47 AM
Ok, so if nobody can help in this situation, maybe sombody can help - how to calculate z dimention and z,y depend of actual camera's position ? Where can I find proper values?
Posted by Puybaret at Dec 11, 2018, 10:16:41 AM
I tried your program in Safari debugger and the object returned at the line
was "almost" found. By "almost", I mean that your x,y coordinates are wrong, and you should translate them in canvas space, removing rect.x and rect.y (but rect can't be correct because you forgot brackets at the end of canvas.getBoundingClientRect).
You should really learn how to use a JavaScript debugger.
Posted by boe666 at Dec 11, 2018, 11:31:56 AM
I understand my mistake, but can You show me how i can translate them in canvas space ? Maybe some links ?
Posted by boe666 at Dec 11, 2018, 12:45:08 PM
I'm trying to understand this, i think it's depend on camera position (before i think the getClosestItemAt calculate this automaticaly) but without any examples i don't know how to start.
Posted by Puybaret at Dec 11, 2018, 1:04:07 PM
I wrote you how to fix your issue.
Sorry, I can't help you more, it's really basic JavaScript.
Posted by boe666 at Dec 11, 2018, 1:24:46 PM
so, if I understand this proper. I have to translate x,y coordinates (given from flat rectangle) to coordinates in the actual perspective of my model's floor. After this, method getClosestItemAt fill return objects.
Am I Correct ?
