Print at Oct 5, 2026, 5:25:56 PM
Posted by OzzieMike at Oct 23, 2016, 7:43:34 PM
Print Dimension
I purchased this app to help with a kitchen remodel. I'd assumed I'd be able to draw the kitchen (which I was able to do), but can't figure out how to have the dimensions print. I need to be able to print the room plan, with dimensions, to take to kitchen design consultant.
Is this possible?
Posted by okh at Oct 24, 2016, 10:00:40 AM
Re: Print Dimension
Did you add the dimension lines in your 2D plan (and set the print preferences to print the 2D plan)? If so, the dimension lines should print.
Or is the background grid you would like to print? If so, see the blog (How to print a grid in the plan or display it in 3D).
