Print at Aug 31, 2026, 11:57:59 AM
Posted by HobbyBouwer at Oct 24, 2016, 5:12:47 PM
Walls not vertically but under 75 degrees
Hello Sweet Home Users,
I look for possibilities to put walls under an angle, ie 75 degrees with horizontal. Walls will standard be drawn under a 90 degree angle. Is that possible????
Thanks HobbyBouwer NL
Posted by Puybaret at Oct 24, 2016, 5:49:58 PM
Re: Walls not vertically but under 75 degrees
No, it's not possible, walls angle with the floor is always 90°. See this tip if needed.
Posted by Miker777 at Oct 24, 2016, 10:55:19 PM
Hi HobbyBouwer
If you position the walls you require, add windows, doors etc, then export it, on importing you could tip it to 75 degrees. If you do not require doors or windows, then i would suggest using the shape generator, this would enable to create a rhombus, keeping top and bottom surfaces horizontal.
Hope this helps.
