Print at Aug 31, 2026, 12:06:15 PM
Posted by ersteinmal at Oct 27, 2016, 8:00:12 AM
heating, Water and air pipes
Dear all.
Intro: I stoppend my searching at Sweet Home because the Drawing is very simple.
But, my aim was, to sign pipes into my hause.
Is there a Way?
Regards Carsten
Posted by Davvey at Oct 27, 2016, 10:02:53 AM
Re: heating, Water and air pipes
Hi
Yes there is a way to do pipes.
I did it by making a small circular wall and then exporting it as a piece of furniture. Then re-importing this and scaling it. I also made a small rectangular set of walls and exported that as trunking.
Posted by Davvey at Oct 27, 2016, 10:07:01 AM
Sorry forgot to say also made right angle bends in both tube and trunking by using sloping walls to make half of a bend then imported it twice to get 2 halves. Then set them up as right angle bend and exported the 2 together to make bend.
Posted by VeroniQ at Oct 27, 2016, 7:24:53 PM
You can find some hot and cold tubes in the example 6 of the gallery
Posted by dorin at Oct 28, 2016, 1:47:24 PM
I use some furniture library for pipes or wire. This is the result:
