Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) |
| Print at Sep 26, 2026, 4:54:50 PM | |
| Posted by ejneafsey at Nov 24, 2016, 1:41:23 PM |
SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Running Xubuntu 16.04. I downloaded new 5.3 version of SH3D. It gave me the 3D error. I then upgraded to latest Nvidia driver (375.20). Still received the 3D error. Here is the full error message: ====================================================================== eneafse:~/bin/java/SweetHome3D-5.3$ ./SweetHome3D com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7f4168178e90, context 0x7f41680152a8, drawable X11OnscreenGLXDrawable[Realized true, Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@156d498a, Handle 0x180009d, Surface JAWTWindow[0x51134a51][JVM version: 1.8.0_112 (1.8.0 update 112) JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 737 x 359 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x180009d, surfaceHandle 0x180009d, bounds [ 0 / 0 737 x 359 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 737x359], pixels[scale 1.0, 1.0 -> 737x359], visible true, lockedExt false, config AWTGraphicsConfiguration[AWTGraphicsScreen[AWTGraphicsDevice[type .awt, connection :0.0, unitID 0, awtDevice X11GraphicsDevice[screen=0], handle 0x0], idx 0], chosen GLCaps[glx vid 0x28, fbc 0xdf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 16/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0x28], encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0.0, unitID 0, handle 0x7f4168178e90, owner true, JAWTToolkitLock[obj 0x38b9192f, isOwner true, <fb2f30d, 70ecca68>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0x28, fbConfigID 0xdf, requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 16/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], chosen GLCaps[glx vid 0x28, fbc 0xdf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]], awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,737x359], surfaceLock <b66caa, 315a9ccb>[count 1, qsz 0, owner <J3D-Renderer-1>]]] at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:393) at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:765) at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:648) at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:586) at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4602) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2376) at javax.media.j3d.Renderer.doWork(Renderer.java:881) at javax.media.j3d.J3dThread.run(J3dThread.java:271) Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics contextX11Util.Display: Shutdown (JVM shutdown: true, open (no close attempt): 2/2, reusable (open, marked uncloseable): 0, pending (open in creation order): 2) X11Util: Open X11 Display Connections: 2 X11Util: Open[0]: NamedX11Display[:0.0, 0x7f4168001620, refCount 1, unCloseable false] X11Util: Open[1]: NamedX11Display[:0.0, 0x7f4168178e90, refCount 1, unCloseable false] eneafse:~/bin/java/SweetHome3D-5.3$ ==================================================================== Don't know what to do next. Thanks. E.J. Neafsey |
| Posted by Puybaret at Nov 24, 2016, 10:13:10 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Please try also the SweetHome3D-Java3D-1_5_2 script available in the installer version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ejneafsey at Nov 25, 2016, 2:41:09 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Problem solved with the SweetHome3D-Java3D-1_5_2 script! Thanks! |
| Posted by Puybaret at Nov 25, 2016, 6:59:09 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Thanks for your feedback. It looks like I'll have to provide Java 3D 1.5.2 along with Java 3D 1.6.0 for a while with Linux ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by rpax at Dec 6, 2016, 8:05:36 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Seems to be a problem with the onscreen rendering. I'm Using Ubuntu 16.04.1 LTS 64-bit, and an NVIDIA Quadro K2100M. It gives me the following error: Try setting the flag -Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true@Puybaret: Debugging a little bit, seems that something is messed up in the interaction between the creation of the 3D Canvas and the new java3D libraries. I'll take a closer look at com.eteks.sweethome3d.j3d.Component3DManagerBest, -.Rafael. |
| Posted by Puybaret at Dec 9, 2016, 6:49:20 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Rafael, the report just says that the class of the displayed component is com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D and I fear the problem is somewhere else. Did you try the SweetHome3D-Java3D-1_5_2 script available in the installer version? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by rpax at Dec 9, 2016, 7:03:27 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Yes, and it works fine. But I want to use java3d 1.6. With the offscreen it works, at least for me. Is anybody having this problem with the flag set? |
| Posted by dgbutterworth at Feb 7, 2017, 7:14:36 AM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Hi, and thanks for your great works. I had and still have the same problem with a video related error in SH3D 5.3 - (running Mint 17.3) - that's referenced in this thread. Using the SweetHome3D-Java3D-1_5_2 script solved the problem and everything was great. (In fact - before 5.3, I could not load the program for a long time and was using the web start version - which was limiting.) Maybe this too deeply buried to be noted, but I just wanted to note that I still have th same problem with version 5.4 - which is still resolved entirely to my satisfaction using the SweetHome3D-Java3D-1_5_2 script. Thanks again. Shout if I can provide any additional info that would be helpful. dgbutterworth "... until you break it, you'll never know whether it needs to be fixed. so try harder." |
| Posted by dreamcarrior at May 6, 2017, 3:38:59 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) I want to report that using Fedora 25 64-bit version kernel 4.10.13-200.fc25.x86_64 #1 SMP with nvidia card also has the same issue. However, using the Java launcher is able to make it work. Thank you very much! |
| Posted by hansmex at May 7, 2017, 4:56:06 AM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Start SH3D with SweetHome3D-Java3D-1_5_2 , that should solve your problem. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Anna_Smith at Jul 2, 2017, 4:28:32 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Hi, I'm user of ubuntu 16 mate, and from two days I cannot use SweetHome because closes, when I want to go to options or preview. My lap is old.. I3-380M with ATI Mobility Raedon HD 5470 I though the problem was Open Java but It seems not. Can you help me? Thanks. |
| Posted by ghotrix at Oct 10, 2017, 10:19:42 AM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) It just stuck for me during the SH3D execution. |
| Posted by pivotz1 at Nov 5, 2017, 10:20:28 AM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20)Me too here! With driver 387.12. It says, I must refresh my OpenGL drivers! Please check it! |
| Posted by Uatschitchun at Aug 25, 2018, 7:18:25 PM |
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20) Hi, same problem here with bionic 18.04 & nvidia-drivers-390: $ ./SweetHome3DStrangely, when running with iGPU Intel UHD 620, it's running nice. Using SweetHome3D-Java3D-1_5_2 helps with nvidia Need more infos? |
Current timezone is GMT Sep 26, 2026, 4:54:50 PM |
