Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Stairs |
| Print at Sep 29, 2026, 6:45:11 PM | |
| Posted by Mantaray36 at Nov 30, 2016, 4:53:19 PM |
Stairs Hi everyone. I'm new to Sweet Home 3D but loving the programme so far but I wonder if I can get some help? I've tried to model some floating stairs but creating blocks and locking them up against the wall. The problem I'm having is that when I model the next level I can't see the stairs. Is there any way of seeing them or is there something else I should do in this instance? Thanks. |
| Posted by bdfd at Dec 1, 2016, 6:16:52 AM |
Re: Stairs Hi lonely, If I understood well , you can use boxes (seen on the plan) put against a wall at the good position... The best wil be a small drawing of you want to do. ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Mantaray36 at Dec 1, 2016, 8:55:13 AM |
Re: Stairs Thanks bdfd. Creating the stairs isn't the problem but being able to see them when I add the next level up is. Not sure how I add a photo on here but if you can give me some help I'll post it. |
| Posted by okh at Dec 1, 2016, 9:18:18 AM |
Re: Stairs If the question is how to cut the ceiling/floor above, you can either draw the floor above manually, or export the staircase as .obj and re-import it checking the 'staircase' option. That way the model will make the cut-out (when reaching the ceiling). If you need a more elaborate cut-out, you need to use the Furniture Library Editor available on the download page. You can find more about how to enter the cut-out shape in the forum or the SVG mini guide. ok |
| Posted by bdfd at Dec 1, 2016, 12:05:02 PM |
Re: Stairs Not sure how I add a photo on here but if you can give me some help I'll post it. I choosed 'mediafire.com' for example but you must create a account.Upload your drawing on it and click on 'share options' to get the 'direct link' and copy-paste in the forum. ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Mantaray36 at Dec 1, 2016, 12:23:21 PM |
Re: Stairs okh's suggestion sorted out my problem. I had previously tried to export my stairs to an OBJ file and selected Staircase but it didn't work. I now know that the stairs have to reach exactly to the ceiling in order to make them show. Thanks for your help everyone. |
Current timezone is GMT Sep 29, 2026, 6:45:11 PM |
