Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Multi-Level Walls |
| Print at Sep 25, 2026, 10:56:27 AM | |
| Posted by tinboye at Dec 13, 2016, 6:47:12 PM |
Multi-Level Walls So I am not sure what to do here, My basement foundation is roughly 8" thick, I have a landing level which is also part of the basement foundation which is also 8" thick, then I have my main level walls which are 4.625" walls. which are inline with the exterior of the walls. I created my basement foundation exterior walls, and copied that into the next 2 levels, then shrunk the main level walls to 4.625" but I am not able to see the basement walls on the main level floor plan view. I would like to be able to see both walls so i can adj, the main floor walls, and not have to redraw them. I was able to see both walls overlayed in the past. anyone able to help? |
| Posted by Puybaret at Dec 13, 2016, 7:12:31 PM |
Re: Multi-Level Walls The walls of lower level are drawn in an upper level only if their top is higher than the floor elevation of the upper level. So change the height of the basement walls accordingly, making them one millimeter (or even less) higher than the main level elevation (don't forget to take into account the thickness of the floor). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 10:56:27 AM |
