Print at Sep 25, 2026, 10:29:46 PM
Posts: 14   Pages: 2   [ 1 2 | Next Page ]
Posted by jkhoo at Dec 25, 2016, 8:59:50 AM
Connecting 2 different levels of ceiling with right angle board.
My ceiling have 2 levels, one at 2900mm and another at 3100mm. How can i connect both of them together with a right angle ceiling?
Posted by bdfd at Dec 25, 2016, 7:47:33 PM
Re: Connecting 2 different levels of ceiling with right angle board.
If I understood, with a raised box with correct dimensions. smile
Posted by jkhoo at Dec 26, 2016, 12:53:39 PM
Many thanks for reading my post. My house have a lower plaster ceiling (about 2900mm from the floor) at the kitchen area and ceiling at the rest of the house is higher (3100mm from the floor). When i built my wall in sweethome3d utility, i spec the kitchen wall at 2900mm height and the rest of the house wall at 3100mm height. When i turn on the ceiling i notice the ceiling become uneven in the area where the wall are of different height. How do i solve this problem?
Posted by FDpaffie at Dec 26, 2016, 3:27:04 PM
post a picture it will help to solve the problem
To Draw or not to Draw ...... Thats nolonger a question .. We draw
Posted by jkhoo at Dec 27, 2016, 3:19:08 PM
Hi FDpaffie,
I just post a picture in the facebook link you provided.
Here are the picture showing 2 wall with different height. How can i make the ceiling flat on the high wall while the ceiling will turn 90 degree angle as it meet the lower wall.
Posted by jkhoo at Dec 27, 2016, 3:21:50 PM
Posted by FDpaffie at Dec 27, 2016, 5:33:30 PM
There are 3 ways to solve that .one is what bdfd was telling
Second one is make one wall a slopingwall ,but that gives you a celing high at one end and lower at the other end
Third option is greate a room in a room the kitchen smaller and lower..
Ps wat i mend was put a picteure on this forum. But it ok
Posted by FDpaffie at Dec 27, 2016, 5:44:32 PM
Greate a room in a room compleet whith walls just a few milimeeters smaller
Posted by bdfd at Dec 27, 2016, 6:12:19 PM
If I'm right, follow this :
Create a box with :
Elevation = 2.9 m
Width = L + 0.02 m
Depth = l + 0.02 m
Height = 3100 - 2900 => e = 0.20 m
Please let us know.
Posted by Miker777 at Dec 27, 2016, 6:49:48 PM
Hi jkhoo
Is this is the sort of thing you are after
If it is then you can download the Stepped celing sh3d file from here . Measurements can be made to suit your project, check the room properties to see how it can be used.
Hope this helps
