Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Spherical sky without 3D ground |
| Print at Sep 28, 2026, 10:57:32 PM | |
| Posted by enkonyito at Jan 3, 2017, 3:57:29 PM |
Spherical sky without 3D ground Is it possible to modify the source code of SH3D to "hide" the 3D ground in order to use an HDRI image in a spherical sky? ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Mar 30, 2017, 1:29:51 AM |
Re: Spherical sky without 3D ground It is possible to hide the creation of 3D ground in the PhotoRenderer.java file. A simple solution is to use an invisible texture for the ground in SH3D but the .hdr format is not supported as sky texture. Here are the results obtained in Sunflow with .hdr files. With ground Without ground ---------------------------------------- EnkoNyito |
| Posted by VeroniQ at Apr 1, 2017, 4:43:09 PM |
Re: Spherical sky without 3D ground Interesting! Thank you for proposing this solution. But the rabbit is flying, now... |
| Posted by enkonyito at Apr 8, 2017, 1:14:27 AM |
Re: Spherical sky without 3D ground But the rabbit is flying, now... The Sunflow interface is not convenient for viewing scene changes.Blender accepts the .hdr format, you could better place a 3D object so that it fits into a real image. Maybe one day Sweet Home 3D will also accept this image format. ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 28, 2026, 10:57:32 PM |
