Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: create a wall with the same height but with different starting elevation |
| Print at Aug 10, 2026, 1:05:26 PM | |
| Posted by Pincio at Jan 5, 2017, 2:37:31 PM |
create a wall with the same height but with different starting elevation Hello I would like to know how to create a wall with the same height but with different starting elevation from that of the arrival, both NOT at the floor level. Thanks for the attention |
| Posted by Puybaret at Jan 8, 2017, 3:33:57 PM |
Re: create a wall with the same height but with different starting elevation Not sure to understand your problem. Can't you set the heights you want on walls with the Height at start and Height at end values available in the Wall modification pane? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Miker777 at Jan 8, 2017, 5:04:03 PM |
Re: create a wall with the same height but with different starting elevation Hi Pincio As far as i know, walls always start at 0 (floor hieght), could you use a box (which can be elevated) instead of a wall? |
Current timezone is GMT Aug 10, 2026, 1:05:26 PM |
