Print at Aug 10, 2026, 3:42:29 AM
Posted by senomesig at Jan 17, 2017, 1:02:01 AM
Can't open file
Hi together,
thanks for this great program, I enjoy it very much! Unfortunately my computer crashed, and now SH3D says, it can't open the file. This is a catastrophe, I spent days working on this file sad
Posted by Puybaret at Jan 17, 2017, 9:04:55 AM
Re: Can't open file
If you use Sweet Home 3D under Windows, check in the subfolders of C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\work (where user is your login) if there are some files starting by open and ending with .sweethome3d. If such files exist, copy the most recent one, change its extension by .sh3d and try to open it with Sweet Home 3D.
If you're under Mac OS X, you should rather search in the subfolder Library/Application Support eTeks/Sweet Home 3D/work of your user folder and if you're under Linux, in the subfolder .eteks/sweethome3d/work of your user folder.
If this didn't help, send me your file, I'll check if I can recover something.
Posted by senomesig at Jan 17, 2017, 10:32:39 PM
applause   Re: Can't open file
WohoOoOo!!!! It worked!! Almost everthing is there again, I'm so happy I'm going to spend you a virtual beer!!! biggrin
Thank you very much!!
Have a nice time!!!
