Print at Sep 29, 2026, 6:45:00 PM
Posted by rhawke at Jan 27, 2017, 7:19:05 AM
Recalculate Room Points
After I move a wall by a few inches or move a door left or right along a wall, I have to update the room. Right now the easiest way is to delete the room and add it again with double click (because fixing the room to match a moved door manually takes a long time).
But then I have to select the textures again, change labels, etc.
It would be nice to have a button inside the "Modify Room" dialog box that lets you recalculate the room points (basically same calculation as when I double click in the center of the room). You could simulate this by assuming I double clicked into the center of the selected room.
Or is there already a good approach to this problem that I am missing?
Posted by Puybaret at Jan 27, 2017, 4:52:02 PM
Re: Recalculate Room Points
I had the idea to add an option to recalculate rooms like you proposed.
But I already introduced a solution to simplify this operation: cut the room, create the room with double click and select Edit > Paste style menu item.
Posted by rhawke at Jan 27, 2017, 5:04:45 PM
Thanks Emmanuel, this is a good tip. I will use this from now on!
For new users the idea to have a button to recalculate would be nice though, so if it is easy to implement I think it would a way to make the software even more intuitive and user friendly (It already is AWESOME!)
Posted by Miker777 at Jan 27, 2017, 7:10:52 PM
Hi rhawke
Sounds like a good idea to me, i never get door positions right 1st time, or 2nd come to that.
Posted by shoulders at Oct 15, 2022, 3:55:21 PM
Is this an easy thing to make into a macro attached to a mouse context menu?
thanks
Posted by fabiin at Jul 26, 2023, 11:49:24 PM
+1
I was seeking for the feature described here.
Pasting style does not work for options other than style like room name, display area, label and area position.
Posted by Puybaret at Sep 24, 2023, 3:07:42 PM
Recalculate room points item was added to plan contextual menu of version 7.2.
You have to select a room and right click at a point where the room points should be recalculated to get this menu item. If the points don't need to be recalculated, the menu item won't appear.
