Print at Oct 5, 2026, 6:26:58 AM
Posted by rantsu at Feb 2, 2017, 6:29:50 PM
Program goes black
When installing the new version (5.3 and 5.4) of sweet home to open the second after it goes to black, I use win vista and updated java, I do not know what I can do, I hope someone can help me ...
Posted by Puybaret at Feb 3, 2017, 1:00:51 AM
Re: Program goes black
Do you mean that the whole window is black, or only the 3D view (the part at the bottom right)?
There was a major change on the management of the 3D view between version 5.2 and 5.3. Does it work with version 5.2?
Posted by rantsu at Feb 3, 2017, 3:56:45 PM
The program window if it opens, maybe 2 seconds pass and the notebook screen goes black and the program is closed
The version 5.2 works perfectly everything, is when I do the update I appeared the problem
Posted by bdfd at Feb 4, 2017, 5:33:40 AM
I had the same problem with a computer of 2010 (it had to stay in 4.6 !!!). biggrin
This was due to the opengl and directx drivers. angry
Try updating them if you have not already done so.
Verify java update.
What year is your notebook, your OS ?
Good luck.
Posted by rantsu at Feb 4, 2017, 3:51:07 PM
Hello, bdfd
Good look for both drivers and only appears directx 11
Java version 8 update121
My notebook is from 2007 win vista home basic 32 bits
Always try to have everything updated the only guy who does not want to update is adobe
I do not know what else can I tell you a weird problem, right?
