Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Splash screen and no more on El Capitan with first time, fresh install. |
| Print at Oct 3, 2026, 3:34:45 PM | |
| Posted by gremio at Feb 10, 2017, 3:02:00 AM |
Splash screen and no more on El Capitan with first time, fresh install. OSX: getting splash screen and nothing more. El Capitan 10.11.6 on MacBook Pro Retina 15" Launching it at console, I get the splash screen and no more as before, and on console: [JavaAppLauncher] Requested [1.5*], launching in [1.8] instead. Java 3D: implicit antialiasing enabled Exception in thread "J3D-Renderer-1" java.lang.UnsatisfiedLinkError: no jogl in java.library.path at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) at java.lang.Runtime.loadLibrary0(Runtime.java:870) at java.lang.System.loadLibrary(System.java:1122) at com.sun.opengl.impl.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:189) at com.sun.opengl.impl.NativeLibLoader.access$000(NativeLibLoader.java:49) at com.sun.opengl.impl.NativeLibLoader$DefaultAction.loadLibrary(NativeLibLoader.java:80) at com.sun.opengl.impl.NativeLibLoader.loadLibrary(NativeLibLoader.java:103) at com.sun.opengl.impl.NativeLibLoader.access$200(NativeLibLoader.java:49) at com.sun.opengl.impl.NativeLibLoader$1.run(NativeLibLoader.java:111) at java.security.AccessController.doPrivileged(Native Method) at com.sun.opengl.impl.NativeLibLoader.loadCore(NativeLibLoader.java:109) at com.sun.opengl.impl.macosx.MacOSXGLDrawableFactory.<clinit>(MacOSXGLDrawableFactory.java:53) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:264) at javax.media.opengl.GLDrawableFactory.getFactory(GLDrawableFactory.java:108) at javax.media.j3d.JoglPipeline$QueryCanvas.<init>(JoglPipeline.java:9029) at javax.media.j3d.JoglPipeline.getBestConfiguration(JoglPipeline.java:8793) at javax.media.j3d.Renderer.doWork(Renderer.java:514) at javax.media.j3d.J3dThread.run(J3dThread.java:275) I explore http://stackoverflow.com/questions/21916547/u...jogl-in-java-library-path No dice. I find jogl.jar and related files in /Applications/Sweet Home 3D.app/Contents/Resources/Java/ext So what's with the path, then? On a whim, I copy logl.jar to /Library/Java/Extensions No dice. Help? |
| Posted by Puybaret at Feb 10, 2017, 10:04:16 AM |
Re: Splash screen and no more on El Capitan with first time, fresh install. How did you install the Sweet Home 3D version you tried? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by rli at Feb 26, 2017, 6:16:34 PM |
Re: Splash screen and no more on El Capitan with first time, fresh install. I have the same problem. I installed in two ways: - Using brew cask install sweet-home3d - Following the instructions from the user guide No lunch, in both cases :( |
| Posted by Puybaret at Feb 26, 2017, 6:55:45 PM |
Re: Splash screen and no more on El Capitan with first time, fresh install. I don't know brew and don't maintain any version available through this channel so I can't help you for this. If you tried to run Sweet Home 3D from its .dmg, you should just have to install Java 6 too. If this is what you tried, maybe check the content of the folder ~/Library/Java/Extensions that shouldn't contain Java3D or JOGL libraries. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 3:34:45 PM |
