Print at Sep 26, 2026, 11:11:11 PM
Posted by martiice at Feb 11, 2017, 8:12:35 AM
3D View is Tiny
My floor plan is fine. But I can't find any way to make the 3D view any larger. The image of the 3D view is so tiny you can barely identify the furniture pieces. The floor plan itself is just a rough sketch to help with re-organizing my studio space, but it would really be helpful if I could see the 3D view. Any suggestions would be greatly appreciated.
Posted by bdfd at Feb 11, 2017, 6:03:00 PM
Re: 3D View is Tiny
I think that you are in 'aerial view' mode.
A right clic with your mouse in the lower frame and choose 'virtual visit' mode and locate your virtual visitor to see all the room.
Posted by nzlemming at Mar 6, 2017, 4:00:59 AM
Re: 3D View is Tiny
I have the same problem.
Yhat is a work around, yes, but I was able to zoom in the aerial mode before. I updated recently. Is this a new bug?
regards
~mark
Win7 SH3D 5.4
Posted by nzlemming at Mar 7, 2017, 6:49:48 AM
Re: 3D View is Tiny
Further info - I try to zoom by using CTRL-mouse wheel. The 3D view stutters as if it's going to zoom but then does nothing.
regards
~mark
Win7 SH3D 5.4
Posted by Puybaret at Mar 7, 2017, 7:21:48 AM
Re: 3D View is Tiny
You must have added an object far from the main plan. Zoom out and choose Edit > Select all to find it and remove it.
Posted by nzlemming at Mar 7, 2017, 10:12:22 PM
applause   Re: 3D View is Tiny
C'est vrai! I had created a room and then moved it because it was getting in the way when I was moving furniture about. Thank you, Emmanual.
Posted by nzlemming at Mar 7, 2017, 10:14:36 PM
Re: 3D View is Tiny
Of course, I then had to mis-spell your name #doh
Thank you, Emmanuel
biggrin
~mark
