Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Generated Photo is always blank |
| Print at Sep 25, 2026, 10:45:50 AM | |
| Posted by sergiopss at Mar 31, 2017, 4:39:18 PM |
Generated Photo is always blank Hi, After adding a room to my project, after that moment I can't generate anymore a photo or video in hight quality when using "Virtual Visit" view since the generate image is always blank. If I delete the room is ok again. Here is a print screen for best understanding: IMAGE I've searched for possible fix but without results... Any help? Thanks. |
| Posted by bdfd at Mar 31, 2017, 5:15:06 PM |
Re: Generated Photo is always blank Hi, Hi,After adding a room to my project, after that moment I can't generate anymore a photo or video in hight quality when using "Virtual Visit" view since the generate image is always blank. If I delete the room is ok again. Here is a print screen for best understanding: IMAGE I've searched for possible fix but without results... Any help? Thanks. I had the same problem after adding a fairly large object. We have thus reached the possibilities of the software (either in memory or in the number of objects present, ...). You need to simplify your project... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by sergiopss at Mar 31, 2017, 5:43:37 PM |
Re: Generated Photo is always blank Hi, thanks for the reply but that's not a solution since I'm only making a simple prototype... I only have about 10 simple objects and this only happens when I add the room, even without textures. |
| Posted by sergiopss at Mar 31, 2017, 6:09:08 PM |
Re: Generated Photo is always blank Hummm, my bad... I just realize that my view probably was above the ceiling (can't realize that on the 3d view). When rendering, it was rendering by beautiful white ceiling... Problem solved! |
| Posted by bdfd at Mar 31, 2017, 7:29:26 PM |
Re: Generated Photo is always blank Hummm, my bad... OK !I just realize that my view probably was above the ceiling (can't realize that on the 3d view). When rendering, it was rendering by beautiful white ceiling... Problem solved! The center of the point of view had moved... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Sep 25, 2026, 10:45:50 AM |
