Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: how do I move a level? |
| Print at Oct 14, 2026, 7:33:04 AM | |
| Posted by TungstenE2 at Apr 24, 2017, 6:32:41 PM |
how do I move a level? Hi, how do I move a level? I have tried as described here: http://www.sweethome3d.com/support/forum/viewthread_thread,6687#29155 But I do not have a numeric box available in the modify level window. Please help. I have version 5.4 thx |
| Posted by Puybaret at Apr 25, 2017, 8:07:47 AM |
Re: how do I move a level? Please give more details about what you mean by "I do not have a numeric box". Can't you edit the elevation of each level, one after the other? Is a control disabled and you don't understand why? Did you read also my answer or what didn't you understand in that answer? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Apr 25, 2017, 8:19:27 AM |
Re: how do I move a level? Hi, Hi,how do I move a level? I have tried as described here: http://www.sweethome3d.com/support/forum/viewthread_thread,6687#29155 But I do not have a numeric box available in the modify level window. Please help. I have version 5.4 thx hummm, I see that you want (I hope). When you have ONE level, you cannot 'move' (or elevate) this level. You must add a new level and a new tab appears (level 0 and the new level 1). Now, you can double-click on level 0 and update the datas... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by TungstenE2 at Apr 25, 2017, 7:25:03 PM |
Re: how do I move a level? I have 4 levels. The last added level is the ground an needs to go to the lowest level. The arrows to move the levels are disabled. Please see screenshot. https://drive.google.com/open?id=0B2X_7NI9zMovWTRhbkxvQl9USzQ What am I doing wrong? |
| Posted by TungstenE2 at Apr 25, 2017, 7:26:35 PM |
Re: how do I move a level? https://drive.google.com/open?id=0B2X_7NI9zMovZlR3NDkwOVdTcDg |
| Posted by okh at Apr 25, 2017, 7:47:23 PM |
Re: how do I move a level? Maybe I miss something, but why do you not just enter a different value for 0 Grundstück + UG? If you enter, say, 100cm (instead of 1048cm) the level should drop automatically. ok PS The comma in 1,048 is a bit confusing, comma is a thousands separator that comes with the English language. If you change to German, French, or something, the numbers will make more sense. |
| Posted by TungstenE2 at Apr 26, 2017, 7:21:06 AM |
Re: how do I move a level? thx, I did not set the elevation. Original language was german, but I wanted to check why I did not have the mentioned numeric box and changed language. Will try to change the elevation, but the question remains why the up and down arrows are deactivated. Also renaming the levels does not resort them automatically, as mentioned in other post. I do not find a simple description on how to move the level and it is not self explaning. |
| Posted by okh at Apr 26, 2017, 7:28:29 AM |
Re: how do I move a level? The arrows are for sorting levels with same elevation, so if you set your Grundstück to 0, you will be able to put Grundstück and Keller in the right order on the same level. For instance if you want to see one level with plan, without seeing the furniture on the same plan. ok |
| Posted by Miker777 at Apr 26, 2017, 6:00:23 PM |
Re: how do I move a level? To change, rename or modify each level, double click on, for example, level 0, this can be found directly above and left of the 2d window, you will need to do this for each level separately. Do not forget to add the floor depth to the wall height. Mike |
| Posted by Miker777 at Apr 26, 2017, 6:09:25 PM |
Re: how do I move a level? Grundstück elevation 0 floor thickness 0 hieght 250 3keller 262 12 250 1eg 524 12 250 2og 786 12 250 |
| Posted by TungstenE2 at Apr 26, 2017, 6:47:59 PM |
Re: how do I move a level? thx, this helped a lot! may be this should go to the documentation/wiki. |
Current timezone is GMT Oct 14, 2026, 7:33:04 AM |
