Print at Oct 12, 2026, 3:12:08 PM
Posted by Jibness at May 3, 2017, 1:46:28 PM
confused   Open double door needed
hi, I am getting slightly frustrated with the open door model. I have been trying to create an open double door using the single door but I end up with a frame in the centre of the doors. I have tried to import different open double door models from various sites but when I place them they go to the thickness of the wall its being placed in and you carn't see the open door correctly. Does anyone have a suggestion or a reliable model I can use I just need an open double door with no glass that shows up correctly when placing it within a wall like the single door does.
Posted by Puybaret at May 3, 2017, 4:22:19 PM
Re: Open double door needed
Did you disable magnetism to be able to resize the depth of the door once you place it on the wall?
Posted by Bubblobill at May 21, 2017, 2:30:39 PM
This is an edited version of the one that came with the program, just two open doors stitched together with the center frame removed. Hopefully it fits what you are looking for.
Open Double Door
Posted by Puybaret at May 21, 2017, 2:56:29 PM
Bubblobill, thanks for trying but the faces of the 3D model you proposed are not well oriented when imported in Sweet Home 3D : I guess you forgot to select the option Mesh > Normals > Flip Normals on the mirrored door you created in Blender.
By the way, it's clearly a work derived from the open door available in Sweet Home 3D and the OBJ file should repeat the same license in its header when you redistribute a modified version (OBJ file is a text file, so it's easy to update it). Of course, you can add in this header your name as a contributor.
Posted by Bubblobill at May 22, 2017, 4:42:49 AM
I thought I had fixed the normals. I'll get the hang of this one day.
Thanks for providing the link to the source. This version includes original license and source.
Updated Open Double Door
Posted by okh at May 24, 2017, 7:33:43 PM
Nice. After seeing the lamp , it is pretty clear you can work your way around PluginFurnitureCatalog.properties. The door might be even more useful with cut-out, door openings and wall alignment smile. A double door, I am sure, could come in handy to quite a few SH3D users. ok
Posted by stef.salmon at Nov 5, 2018, 1:41:15 PM
The double door is what I've been looking for. If I drop the door onto a wall it still has a frame in between the doors.
I'm obviously doing something wrong?
Posted by alaX at Nov 7, 2018, 2:35:30 PM
Download Furniture Library Editor , load your model, select "Door or window", select "Customized cut out shape (SVG)" and type in "M0,0 v1 h1 v-1 z". Give a name, choose category etc. and save.
Or download this model (#509 ) - if you have SH3D 6.0 you'll be able to open the door.
Posted by stef.salmon at Nov 9, 2018, 8:31:44 AM
That's just the job. Thanks alaX wink
