Print at Oct 3, 2026, 2:27:14 AM
Posted by narnal at May 6, 2017, 9:12:43 AM
cant not open, 'modify walls...' dialogue
Right click 'Modify Wall' on 'wall' and 'popup dialog' does not appear.
Click again and there is no response.
screenshot : https://i0.wp.com/www.dolzikoo.com/wp-content...size=1024%2C720&ssl=1
OS: windows 10 64bit.
Posted by Puybaret at May 7, 2017, 10:59:57 AM
Re: cant not open, 'modify walls...' dialogue
Could you check if there's some error log that could explain your issue?
Please open a cmd window and run Sweet Home 3D redirecting errors to a file with a command like:
"C:\Program Files\Sweet Home 3D\SweetHome3D.exe" 2> Desktop\log.txt
If the file log.txt contains something, please post it here.
Posted by Nio at May 13, 2017, 3:00:36 PM
I am also facing the same problem ...
Posted by Nio at May 13, 2017, 3:41:50 PM
I get that log.txt file after I launch sweet home 3d by command prompt ....as you said..
Posted by Puybaret at Aug 25, 2017, 6:54:37 PM
The log file you posted reports an error in the look and feel, and I'm not sure I can fix that.
Please, try to use a different Windows theme, or run Sweet Home 3D with a different look and feel by adding a file named SweetHome3D.l4j.ini in the same folder as SweetHome3D.exe and writing the following line in it (with the starting hyphen):
-Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel
Hope this will work...
