Print at Oct 8, 2026, 8:22:41 AM
Posted by denmyos at Jul 6, 2017, 3:16:21 PM
rendering transparent
Designing a pool for my mom inlaw, i have come across something odd.
In 3d view i can adjust the water with "modify 3d view" "Walls transparency" And the transparency is fine.
But when i want to render it, its solid.
Is it me, or is there a bug in the program.
Thanks. :)
Posted by okh at Jul 6, 2017, 4:36:39 PM
Re: rendering transparent
Neither, I suspect. The 3D view walls transparency does not actually make the walls transparent (walls cannot be transparent in SH3D), it is only a design tool to make it easier to see what you are doing (see recent blog: How to show interior parts hidden by walls).
Not sure what you (well, your mother in law) wish(es) to achieve, but you can import a box as a window and apply a transparent texture. See also thread 2954 with attachments.
Posted by denmyos at Jul 6, 2017, 6:16:15 PM
I just wanted to make the water of the swimming pool transparent.
I know there is a tutorial on this site about it, but I could not get it to work.
Posted by okh at Jul 6, 2017, 8:13:03 PM
Was it the blog: How to design a swimming pool you could not get to work? If so, which part? ok
Posted by bdfd at Jul 7, 2017, 6:28:43 AM
Maybe use a water texture...
Few weeks ago, I put a picture of a sink.
It's the same thing for a pool.
Posted by denmyos at Jul 7, 2017, 8:10:55 AM
Yes that was the one.
For some reason the water (room) stayed opaque.
Only the walls got transparent when I moved the slider.
I tried a dozen times.
Posted by hansmex at Jul 7, 2017, 9:24:38 AM
Use Modify rooms --> Display ceiling
When the ceiling disappears, you can see the "room"
