Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Menu all crammed together |
| Print at Sep 28, 2026, 4:05:35 AM | |
| Posted by Hoover101 at Jul 30, 2017, 9:24:45 PM |
Menu all crammed together Just installed. The menu on the top left is all crammed up vertically and only shows about the top 1/3 of each menu title |
| Posted by Puybaret at Jul 31, 2017, 8:35:25 AM |
Re: Menu all crammed together You're probably using a HiDPI screen in which case you should look at the FAQ Texts in the furniture catalog are not displayed correctly or icons in the toolbar appear very small on my computer. How can I fix that? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Hoover101 at Jul 31, 2017, 3:33:04 PM |
Re: Menu all crammed together Did that, followed the directions, updated Java, restarted computer and Sweet Home 3D but still encountering same problem |
| Posted by Hoover101 at Aug 4, 2017, 1:36:47 PM |
Re: Menu all crammed together Sooo... any additional help or just live with it?? |
| Posted by Puybaret at Aug 4, 2017, 2:17:05 PM |
Re: Menu all crammed together I would double check the suggestion of the FAS. And if it still doesn't work, it will be impossible to help you without at least an image... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 4:05:35 AM |
