Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Help needed Improving Plan |
| Print at Oct 19, 2026, 10:58:37 AM | |
| Posted by shaunac93 at Aug 2, 2017, 3:24:17 PM |
Help needed Improving Plan Hi everyone, newbie here. After looking at alot of tutorials and videos i managed to design my own house but i'm really struggling with the first floor rooms and the roof. I've attached pictures and plans and what i have done so far. If anyone could fine tune it for me or explain to me how i can i would be ever so grateful. https://drive.google.com/open?id=0B7e1quvRmc2hRjloMmZ1UlRrVDA |
| Posted by santbose at Aug 16, 2017, 10:20:48 AM |
Re: Help needed Improving Plan I have downloaded the SH3D plan and also the other files. Let me study and then may be able to help you out |
| Posted by VeroniQ at Aug 17, 2017, 10:39:02 AM |
Re: Help needed Improving Plan Hi Shaunac93, Well done, already! However, before starting to decorate the house, may I remark that your external walls (and all the loadbearing walls in general) need a thickness of, at least, 26 centimeters. Also be careful to align correctly them vertically. And check that the rooms are precisely adjust to the walls, especially in the corners. I have also the feeling that the large living room of the Level 0 is too large (in general, I think you need a loadbearing wall every 7 meters). On the level 0, the sort of bow window has no roof (even if it has a ceiling). You may add a "box" on the top of it or design a special roof. What sort of advices do you need for the bedrooms? The roof looks good, but did you notice all the roof textures in the texture librairies? Looking forward to see the deco you imagine in this beautiful house! |
| Posted by hansmex at Aug 17, 2017, 1:08:05 PM |
Re: Help needed Improving Plan You forgot to scale the plans correctly. Your house is anywhere between 35 and 50% too big. So, basically you should start all over again. My suggestion is to draw the ground floor first, then copy all walls to first and second level and adjust (or delete) as needed. That way walls align perfectly. See attached file. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by shaunac93 at Aug 23, 2017, 11:24:05 AM |
Re: Help needed Improving Plan Hi guys thanks for all your help. I have started my plans again and this time i think i have them scaled correctly and matching up vertically but again i need help with my roof https://drive.google.com/open?id=0B7e1quvRmc2hdEtnSUJ1a3V5elU |
Current timezone is GMT Oct 19, 2026, 10:58:37 AM |
