Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Method not accessible from a plug-in |
| Print at Sep 27, 2026, 12:00:31 AM | |
| Posted by enkonyito at Sep 8, 2017, 12:28:22 AM |
Method not accessible from a plug-in By checking the compatibility of the PhotoVideoRendering-1.3 plug-in with SweetHome3D-5.5, I get an error after integrating the PhotoRenderer file update. Error message: "The method getPieceOfFurnitureNormalizedModelTransformation (HomePieceOfFurniture, Node) from the type ModelManager is not visible". PVR-1.3 SH3D-5.5 Is there a way to circumvent this restriction? ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Sep 8, 2017, 12:50:11 AM |
Re: Method not accessible from a plug-in I guessed you would need getPieceOfFurnitureNormalizedModelTransformation, made it public during half an hour, and finally changed my mind because I didn't want that a method with such parameters be part of the API. Just copy / paste it in your own code. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Sep 8, 2017, 11:24:57 PM |
Re: Method not accessible from a plug-in At first the solution did not work but with perseverance the problem was solved. Thank you! ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 27, 2026, 12:00:31 AM |
