Print at Oct 13, 2026, 2:43:55 PM
Posted by bizusomoy at Sep 22, 2017, 7:07:09 AM
no texture on surface
hi, my problem is, after applying texture on furniture when I give final render it shows the only color on the surface but not a texture.what I will do.plz help me.
Posted by bdfd at Sep 22, 2017, 7:39:21 AM
Re: no texture on surface
Can you show us (screenshots) a picture before and after ?
What are the parameters of rendering ?
What is the size of the texture (in pixels) ?
Posted by hansmex at Sep 22, 2017, 7:56:38 AM
Probably a model from the Sketchup Warehouse. Sh*t happens with those.
Posted by okh at Sep 22, 2017, 9:15:21 AM
Probably a model from the Sketchup...
Yes, most likely. Around the forum there are several threads about textures and Sketchup. It is usually possible to fix with Sketchup - making sure that textures/colours only are applied to the outer surfaces (using "Orient faces", "Reverse faces" and avoid and remove the "Two sided faces"). But on a complicated model, that can be a cumbersome process.
In recent versions of SH3D, it is sometimes possible to remove the back surfaces that bleed through and ruin the rendering: If the offending material is listed in the material list (and not used elsewhere) it can be set to invisible. But then you need to be lucky with the model.
Posted by bizusomoy at Sep 22, 2017, 10:31:58 AM
https://www.facebook.com/photo.php?fbid=10214...51&type=3&theater
here in this link, you can see the floor there is no texture but only color.I also use texture on the walls but there is also the same problem.
Posted by Puybaret at Sep 22, 2017, 10:46:22 AM
What version do you use (see About dialog box)?
Would you have duplicated walls and rooms (possibly introduced after a quick copy paste), with a version of these objects textured differently? Just temporarily delete one of them to check that.
If this is not the right idea, could you share or send me a simplified version showing the bug?
Posted by bizusomoy at Sep 22, 2017, 11:25:32 AM
I m using 5.5 version.I did but there are the same thing happening,
Posted by Puybaret at Sep 22, 2017, 11:50:35 AM
So please, share or send me a simplified version showing the bug?
Posted by qythyx at Sep 25, 2017, 8:39:12 AM
I sometimes see something similar. It happens when I'm rendering a video, or even just single images multiple times (different view points, etc). Sometimes the texture is fine, but sometimes it's just grey.
Do others see this? Any ideas?
