Print at Sep 25, 2026, 10:54:27 AM
Posts: 22   Pages: 3   [ 1 2 3 | Next Page ]
Posted by RebTech at Oct 12, 2017, 5:12:21 AM
Windows 10 display issue
every time I start the program and try and move my mouse around...this is what I end up with?
any solutions to this video display issue? using the lattest ver
Version 5.5.2 Java version 1.8.0_144 / 64 bit / 5 GB max
Posted by Puybaret at Oct 15, 2017, 6:03:00 PM
Re: Windows 10 display issue
Could you try to reinstall the program using the options described here?
Posted by Treglis at Oct 16, 2017, 9:40:00 PM
I had the same issue. This helped me to solve the problem http://www.sweethome3d.com/support/forum/viewthread_thread,7628#34466
Posted by Nik_2213 at Jan 18, 2018, 3:14:40 AM
Are you using the bundled graphics driver, which may be optimised for gaming ? You may need a generic driver from the chip-maker eg Nvidia...
Posted by Scrati at May 2, 2018, 9:40:09 PM
I have the exact same problem with version 5.7 and before. I even tried 3.6 which I found in one of my backup folders.
I tried the hints in post number 2 and 3 and I have original graphics drivers installed.
Has anybody any ideas?
Posted by sfcusaoh at May 24, 2018, 2:35:30 AM
I am having the same problem...
I have Sweet Home 3D version 5.7 and Java jre1.8.0_171 installed on an Asus G752VL i7 2.6GHz processor with 12GB ram running Win10 64bit.
Replacing the Sweet Home 3D bin & lib files with the Java bin & lib files did not correct the issue.
Does anybody have any ideas?
Thanks in advance for your help...
Posted by dusho at Aug 14, 2018, 9:26:23 PM
Also having this issue and nothing from what is mentioned here helped. Tried portable, tried jre 1.6, tried sh3d version 3.4, tried disabling java3d by env. variable (now causing directX/opengl error at start up).
Issue starts right away when any tooltip appears, then it feels like re-paint is totally messed up (almost like double buffer content is painted where your mouse is).
Found also other SW with similar reports: https://github.com/chatty/chatty/issues/69
My setup is Win10, 64-bit, Asus G752, Nvidia GTX1070, factory drivers
Posted by ErikJan at Oct 26, 2018, 8:23:56 AM
Exactly what I see too
Posted by MoritzWb at Dec 18, 2018, 7:12:48 PM
Same here, still no solution?
Posted by Puybaret at Dec 19, 2018, 8:53:30 AM
From version 6.0, the destination folder screen in Sweet Home 3D installer shows Architecture options to install the program in 32 bit or 64 bit. Did you try the 32 bit option?
