Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can't start sweethome3d on Linux |
| Print at Sep 25, 2026, 12:21:48 PM | |
| Posted by simona70 at Oct 22, 2017, 9:45:06 AM |
Can't start sweethome3d on Linux Intel z270, i7-7700K, Linux 4.13 (4.13.8-1-zen), arch linux distro, Sapphire NITRO+ RADEON RX 580 Special Edition 8G GDDR5, amdgpu driver, 16gb ddr4, de KDE. system full updated, Linux-zen kernel. Extended renderer info (GLX_MESA_query_renderer): Vendor: X.Org (0x1002) Device: Radeon RX 580 Series (AMD POLARIS10 / DRM 3.18.0 / 4.13.8-1-zen, LLVM 5.0.0) (0x67df) Version: 17.2.2 Accelerated: yes Video memory: 8143MB Unified memory: no Preferred profile: core (0x1) Max core profile version: 4.5 Max compat profile version: 3.0 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.1 OpenGL vendor string: X.Org OpenGL renderer string: Radeon RX 580 Series (AMD POLARIS10 / DRM 3.18.0 / 4.13.8-1-zen, LLVM 5.0.0) OpenGL core profile version string: 4.5 (Core Profile) Mesa 17.2.2 OpenGL core profile shading language version string: 4.50 OpenGL core profile context flags: (none) OpenGL core profile profile mask: core profile I get the splash screen and then nothing happens. Running from a console, I can see the error messages/call stack. I especially notice: Exception in thread "main" java.lang.InternalError: XXX0 profile[1]: GL3bc -> profileImpl GL4bc !!! not mapped Full call stack from error: Exception in thread "main" java.lang.InternalError: XXX0 profile[1]: GL3bc -> profileImpl GL4bc !!! not mapped at com.jogamp.opengl.GLProfile.computeProfileMap(GLProfile.java:2071) at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1924) at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1875) at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.java:1843) at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80) at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:230) at java.security.AccessController.doPrivileged(Native Method) at com.jogamp.opengl.GLProfile.initSingleton(GLProfile.java:216) at com.jogamp.opengl.GLProfile.getProfileMap(GLProfile.java:2297) at com.jogamp.opengl.GLProfile.get(GLProfile.java:1021) at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050) at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803) at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267) at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:317) at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:207) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source) |
| Posted by hansmex at Oct 22, 2017, 11:35:58 AM |
Re: Can't start sweethome3d on Linux The Linux version comes with a startup-script called Java-1.5 or something similar. Use that script to start SH3D. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by simona70 at Oct 22, 2017, 3:02:59 PM |
Re: Can't start sweethome3d on Linux Sorry.... in my aur arch linux sweethome3d package I don't find any java script (there is a .desktop ...). Anyone can publish this script content? |
| Posted by hansmex at Oct 22, 2017, 4:34:37 PM |
Re: Can't start sweethome3d on Linux #!/bin/sh # Retrieve Sweet Home 3D directory PROGRAM=`readlink "$0"` if [ "$PROGRAM" = "" ]; then PROGRAM=$0 fi PROGRAM_DIR=`dirname "$PROGRAM"` # Run Sweet Home 3D exec "$PROGRAM_DIR"/jre8/bin/java -Xmx1024m -classpath "$PROGRAM_DIR"/lib/SweetHome3D.jar:"$PROGRAM_DIR"/lib/Furniture.jar:"$PROGRAM_DIR"/lib/Textures.jar:"$PROGRAM_DIR"/lib/Examples.jar:"$PROGRAM_DIR"/lib/Help.jar:"$PROGRAM_DIR"/lib/iText-2.1.7.jar:"$PROGRAM_DIR"/lib/freehep-vectorgraphics-svg-2.1.1b.jar:"$PROGRAM_DIR"/lib/sunflow-0.07.3i.jar:"$PROGRAM_DIR"/lib/jmf.jar:"$PROGRAM_DIR"/lib/batik-svgpathparser-1.7.jar:"$PROGRAM_DIR"/lib/j3dcore.jar:"$PROGRAM_DIR"/lib/j3dutils.jar:"$PROGRAM_DIR"/lib/vecmath.jar:"$PROGRAM_DIR"/jre8/lib/javaws.jar -Djava.library.path="$PROGRAM_DIR"/lib -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer com.eteks.sweethome3d.SweetHome3D -open "$1" ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by simona70 at Oct 22, 2017, 6:16:23 PM |
[solved] Re: Can't start sweethome3d on LinuxSolved.Thanks. It's Archlinux packet in [Community] that is buggy. Original java packet in SweetHome3D site is ok. |
| Posted by richardlyons at Jan 24, 2018, 10:28:50 PM |
[solved] Re: Can't start sweethome3d on Linux I was thrilled to find this script, as I had the same problem on Arch Linux. I had to change "readlink" to "realpath" but SH3D then loaded. Very disappointed that it is not in fact doing any 3D. The bottom right panel remains blank and the plan shows a jumble of white rectangles where furniture and other items should be. Such a pity not to be able to run this application. |
| Posted by richardlyons at Jan 25, 2018, 1:30:08 PM |
[solved] Re: Can't start sweethome3d on Linux In the start script above, it probably depends on your shell, but may be necessary to replace (in line 4) the deprecated "readlink" with "realpath" to get the intended result. |
| Posted by richardlyons at Jan 26, 2018, 9:46:49 PM |
Re: [solved] Re: Can't start sweethome3d on Linux Further explanation of the problem using SH3D on Arch Linux. Installation of the package available for the distro results in only the splash screen. Using the start script is difficult because the libraries listed are located in different directories. It may be possible to edit the script. I have not tried as I am unsure how to select compatible versions. Installing from the SweetHome3D site, it is easy to edit the script to start the program, but the 3D rendering fails. The following errors are generated (it looks as though the first few lines are critical): Java 3D: implicit antialiasing enabled |
Current timezone is GMT Sep 25, 2026, 12:21:48 PM |
