Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Doesn't launch anymore in Ubuntu 17.10 |
| Print at Sep 28, 2026, 11:29:12 AM | |
| Posted by UbuntuBirdy at Oct 24, 2017, 1:05:21 PM |
Doesn't launch anymore in Ubuntu 17.10 There are no problems before in Ubuntu 17.04, but since i've upgradet to 17.10 sw3d does not launch, it does nothing. It's the version from the download section here on the site. If i install the version from Ubuntu-Software, it runs without any problems, but this version has some limitations (e.g. the furniture can only displayed as icons in the plan). ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Oct 24, 2017, 3:24:08 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 If you unpack the download, there's a little program called SweetHome3D-Java3D-1_5_2. Double-click it and then click Run. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Oct 24, 2017, 4:01:48 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 I just tried on a brand new image of Ubuntu 17.10 64 bit, and both scripts SweetHome3D and SweetHome3D-Java3D-1_5_2 run correctly (but with Java 3D 1.5.2, furniture seen from the top in the plan was black). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by UbuntuBirdy at Oct 24, 2017, 4:34:33 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 No luck, both scripts SweetHome3D and SweetHome3D-Java3D-1_5_2 do not run. Seems i have a java problem... ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Oct 24, 2017, 5:16:49 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Check if you have the best video drivers installed. I run Mint 18 (=Ubuntu 16.04?) with the Java script, and everything works perfectly. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by UbuntuBirdy at Oct 24, 2017, 5:34:27 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 It's not easy to run a polaris chip on Ubuntu. That's why i upgradet to 17.10 and always install the newest kernel, and that helps a lot. But a upgradet 17.10 is not a clean system, so there are many many possible problems. And the reason why i run such a system ist the amd ryzen cpu that does not run properly with older ubuntu versions. So, let's stop here, i can accept the limitations i wrote about and i will wait for 18.04 and then do a clean fresh installation. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by UbuntuBirdy at Apr 28, 2018, 4:48:01 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Now i'm running a clean and fresh installed Ubuntu 18.04, all works fine, except for sweethome3d... Same limitations as in 17.10 if the program ist installed from the software center. no luck if i download it from here, then it is impossible to start sweethome3d. For now it seems to me like the problem is not java, i beleve its the video drivers. there are lots of improvements in other grafical software since 18.04, but not in sweethome3d on my machine... ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by Golia at Jun 5, 2018, 7:28:28 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 it's like that for me too. With ubuntu 18.04 the sweet home graphic is very bad. Forniture Library Editor and Texutures Library Editor do not open files. Has anyone else tried with ubuntu 18.04? Sorry for my translated English Good day |
| Posted by UbuntuBirdy at Jun 5, 2018, 9:58:26 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Oh man, i'm no longer alone! Are you running the version from the softwarecenter in Ubuntu or the version downloaded here from the Website? What kind of craphiccard are you using? Brand? Type? ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by Golia at Jun 5, 2018, 8:39:05 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hello I installed from the software center, I also downloaded SweetHome3D-5.7-linux-x64.tgz, unpacked and tried to open the file SweetHome3D or SweetHome3D-Java3D-1_5_2, but nothing. Do I have to install any version of java? which? I do not know English, what does craphiccard mean? let's keep up to date good evening |
| Posted by Golia at Jun 5, 2018, 8:58:24 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 maybe you want to know what video card I have installed? franco@franco-500-511nl:~$ lspci | grep -E 'VGA|Display|3D' 01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Oland [Radeon HD 8570 / R7 240/340 OEM] franco@franco-500-511nl:~$ |
| Posted by Puybaret at Jun 6, 2018, 11:28:26 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Golia, you should install Java 8 to run the Editors. About Sweet Home 3D, what do you mean by "nothing"? Could you run SweetHome3D or SweetHome3D-Java3D-1_5_2 in a Terminal and report what it displays? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by UbuntuBirdy at Jun 6, 2018, 11:37:07 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Sorry, my fault! Graphic card or video card is right what i asked for. You see, english is also a foreign language for me. Ok, it's what i expected, an AMD product (in my mashine there is a AMD RX580) and that's the problem. The radeon-drivers for linux are not yet finished so we have to use a very basic version for our video cards. You can fix some problems in the sweethome3d start script (/usr/share/sweethome3d/sweethome3d.sh). you have to open it with root-rights and modifie the JAVA_ARGS section. I think you can copy and paste mine: JAVA_ARGS=" -Djava.library.path=/usr/lib/jni \ -Dcom.eteks.sweethome3d.applicationFolders=$HOME/.eteks/sweethome3d:/usr/share/sweethome3d \ -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=true \ -Dsun.java2d.opengl=true \ -Dcom.eteks.sweethome3d.resolutionScale=1.25 -Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel -Dswing.plaf.metal.controlFont=Dialog-11 -Dswing.plaf.metal.userFont=SansSerif-11 -Dswing.plaf.metal.systemFont=SansSerif-11" About the Java-version: i'm running version 10 but that means, i have no access to any furniture library. I have to import every single furniture which i want to use. Ok, that's what i can do for you at the moment. For further improvements we have to wait for the new Radeon-drivers (a pre-release is already available) and for java10 support of sweethome3d. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by UbuntuBirdy at Jun 6, 2018, 11:42:24 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 @Emmanuel - Sweethome3D downloaded from here will not start on a system running Ubuntu 18.04 AND a recent AMD video card because of the unfinished radeon-drivers. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by Golia at Jun 6, 2018, 10:48:23 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Emmanuel From SW3d terminal it works correctly, I had not tried from terminal. I try to install java 8 for editors and I'll let you know, thanks UbuntuBirdy I think it's a video card problem |
| Posted by Golia at Jun 6, 2018, 10:49:56 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 FreeCad does not work either I'd better get back to LinuxMint |
| Posted by UbuntuBirdy at Jun 10, 2018, 9:23:05 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 @ Golia - You can run FreeCAD in Ubuntu 18.04. Go to /home/.local/share/applications and open your FreeCAD starter with an Editor. Replace the Exec-entry with this one: Exec=sh -c "LIBGL_DRI3_DISABLE=true freecad" --single-instance %U @Emmanuel - I don't know how long ago i opened SW3D in the terminal, but there semes to be some changes since then. I can now run SweetHome3D-Java3D-1_5_2 in the terminal and SW3D is starting. WAHOOO it's awesome to get the libraries back!!! ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by Golia at Jun 14, 2018, 10:59:10 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Great!! |
| Posted by Golia at Jul 18, 2018, 2:45:34 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hello I installed SH3D and Java 8 on linux Mint 19 (ubuntu 18.04) and at the moment everything is fine. As for the editors (Forniture Library Editor and Texutures Library Editor) do not start but do not open any files. I also found a terminal ... nothing |
| Posted by Golia at Jul 21, 2018, 9:38:17 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Sorry, I did not realize that the java version was 10 instead of the 8 default. For those who served I did so: sudo add-apt-repository ppa:webupd8team/java sudo apt-get update sudo apt-get install oracle-java8-installer sudo apt-get install oracle-java8-set-default but it does not work all right ... TexturesLibraryEditor everything is ok FurnitureLibraryEditor opens the file correctly, when I go to edit an element it closes. under the result from the terminal franco@franco-System-Product-Name:~$ java -jar FurnitureLibraryEditor-1.20.jar com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7f8264156540, context 0x7f82642cd6f8, drawable X11OnscreenGLXDrawable[Realized true, Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@6e425c3b, Handle 0x50002ae, Surface JAWTWindow[0x24534070][JVM version: 1.8.0_181 (1.8.0 update 181) JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 128 x 128 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x50002ae, surfaceHandle 0x50002ae, bounds [ 0 / 0 128 x 128 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 128x128], pixels[scale 1.0, 1.0 -> 128x128], visible true, lockedExt false, config AWTGraphicsConfiguration[AWTGraphicsScreen[AWTGraphicsDevice[type .awt, connection :0.0, unitID 0, awtDevice X11GraphicsDevice[screen=0], handle 0x0], idx 0], chosen GLCaps[glx vid 0x28, fbc 0x10f: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 16/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0x28], encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7f8264156540, owner true, JAWTToolkitLock[obj 0x29967f31, isOwner true, <2e956caa, 52ca4ec7>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0x28, fbConfigID 0x10f, requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 16/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]], chosen GLCaps[glx vid 0x28, fbc 0x10f: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]], awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,128x128], surfaceLock <67c2e5bf, 5af67477>[count 1, qsz 0, owner <J3D-Renderer-1>]]] at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:393) at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:765) at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:648) at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:586) at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4602) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2376) at javax.media.j3d.Renderer.doWork(Renderer.java:881) at javax.media.j3d.J3dThread.run(J3dThread.java:271) DefaultRenderingErrorListener.errorOccurred: CONTEXT_CREATION_ERROR: Renderer: Error creating Canvas3D graphics context graphicsDevice = X11GraphicsDevice[screen=0] canvas = com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,128x128] X11Util.Display: Shutdown (JVM shutdown: true, open (no close attempt): 2/2, reusable (open, marked uncloseable): 0, pending (open in creation order): 2) X11Util: Open X11 Display Connections: 2 X11Util: Open[0]: NamedX11Display[:0, 0x7f826400ff50, refCount 1, unCloseable false] X11Util: Open[1]: NamedX11Display[:0, 0x7f8264156540, refCount 1, unCloseable false] |
| Posted by Golia at Jul 28, 2018, 5:16:06 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 it only happens to me that it does not work FurnitureLibraryEditor? |
| Posted by UbuntuBirdy at Jul 28, 2018, 6:13:20 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Not only to you. I can start it and I can load a library, but I'm not able to do something else... If I execute any of the other functions nothing will happen. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by UbuntuBirdy at Feb 12, 2019, 10:26:50 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Since last week an extensive update for OpenGL was released, I can start SH3D again with the standard script (SweetHome3D; SweetHome3D-Java3D-1_5_2 is not longer needed), so Java3D runs on Ubuntu now also in version 1.6. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Feb 12, 2019, 11:43:55 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Congratulations UB! I'm jealous you can use SH3D out of the box. On my system nothing happens :-( H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by UbuntuBirdy at Feb 12, 2019, 12:04:44 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hans, try the follwoing command in your terminal: glxinfo | grep 'version' Which version of OpenGL does this indicate? ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Feb 12, 2019, 1:03:03 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 And the answer is.... server glx version string: 1.4Problem is: SH3D doesn't do anything at all with either script. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by UbuntuBirdy at Feb 12, 2019, 1:31:48 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hans, you still have to start SH3D via the starter we created. But no longer linking to the 1.5.2 script but to the SweetHome3D script. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Feb 12, 2019, 2:27:47 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Thank you very much, UB, will give it a try! ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by UbuntuBirdy at Feb 13, 2019, 9:01:48 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 After allmost 200h of developing parts, 3D-printing them, figure out if they work, redesign and reprint them (during the last 6 days...) I had now some time left to test FLE and as expected it now works like a dream - thanks to OpenGL 4.5 and higher! ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by UbuntuBirdy at Feb 14, 2019, 6:00:20 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hans, if it still does not work for you, do not bother too much, because the performance of java3d1.6 is much worse than java3d1.5.2... ...wondering why... ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by UbuntuBirdy at Feb 15, 2019, 1:19:15 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 I cannot figure out where the performance loss of java3d 1.6 is coming from and so I had to switch back to java3d 1.5.2. ... very disappointing, but hey, that's life... ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by mrpraline at Mar 4, 2019, 9:45:10 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Don't know if I should start a new thread, but I cannot run Sweethome3d in Ubuntu 18.10. Both of the scripts in the download directory fail to run. With both scripts I get: If I run the webstart version the initial window opens but then I get a pop-up window saying '3D error" and after clicking OK SH3D exits. |
| Posted by UbuntuBirdy at Mar 13, 2019, 3:03:04 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 In your personal folder in .local/share/applications create new file named SweetHome3D.desktop. Copy the following content into it: [Desktop Entry]Edit "/path/to/SweetHome3D-6.1.2" to the location where your SH3D is. At the "Exec"-section you can try the other start script too. This will start SH3D via the terminal. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by mrpraline at Mar 16, 2019, 2:16:18 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hi Pascal, I tried your suggestion, but no success. I should have told you that the messages I got were from staring Sweethome3D from the command line. So I typed both ./Sweethome3D and ./SweetHome3D-Java3D-1_5_2 in the directory where I extracted SweetHome3D-6.1.2-linux-x86.tgz. |
| Posted by UbuntuBirdy at Mar 16, 2019, 4:06:31 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 It was only a try, you have not the same issue as I had. So, what type of video card have you installed? Have you the newest driver for this card? What's the reason for running Ubuntu 18.10 and not the 18.04 LTS? ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by mrpraline at Mar 17, 2019, 11:09:34 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 I'm beginning to think it is related to the graphics card. On my laptop, which is also running ubuntu 18.10, I can run the webstart SH3D if install the java3d and icedtea package. This has an intel graphics chipset. On my desktop, I can't. It is a 12GB core i7 920, using an NVIDIA Geforce 660 Ti. Graphics driver is 390.116. If I open the webstart version I get the program window, but then a window pops up saying 3D error. If I click that it will close the program. |
| Posted by mrpraline at Mar 17, 2019, 11:22:15 AM |
Re: Doesn't launch anymore in Ubuntu 17.10To reply on my own post: I removed and reinstalled all Java stuff on my computer and now I get the same behavior from the command line as from the webstart link if I use the ./SweetHome3D shell command. However if I use the ./SweetHome3D-Java3D-1_5_2 command SH3D starts! SO, I have no idea what was the problem, but now it is gone. |
| Posted by lpalazzotto at Jun 5, 2019, 1:19:18 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hey Pascal: You seem to have learned quite a lot about this problem of Sweet Home 3D not launching in Ubuntu. When I run it to terminal here is what I get: Java 3D: implicit antialiasing enabled Java 3D ERROR : GLX extension is not supported GLX version 1.3 or higher is required Gtk-Message: 23:46:53.643: Failed to load module "canberra-gtk-module" Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException etc. I have Java Oracle 12 installed. What is this GLX 1.3 and how do I fix it? I cannot see it in my system. |
| Posted by lpalazzotto at Jun 5, 2019, 1:21:30 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 P.S. I have Ubuntu 19.04 |
| Posted by dorin at Jun 9, 2019, 5:49:54 PM |
Re: Doesn't launch anymore in Ubuntu 17.10 Maybe out of topic For those who use it under all kind of linux system: Forget about any ppa, synaptic or whatever repository. Usually don't work or don't work correctly for a lot of reasons. That's not the fault of SH3D developer BUT the distribution managers. At this times the space is no more a problem for decent programs. Use the installer version from this site and You will be more happy. e.g.I have a <60G SSD for all system and programs (root, home & swap); SH3D have 140MB + a lot of library and plans all at a half of an ancient movie. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by kazawary at Apr 29, 2020, 9:54:37 AM |
Re: Doesn't launch anymore in Ubuntu 17.10 Hi, Tried the last posters web launch solution but got the following error. net.sourceforge.jnlp.LaunchException: Fatal: Launch Error: Could not launch JNLP file. The application has not been initialized, for more information execute javaws/browser from the command line and send a bug report. at net.sourceforge.jnlp.Launcher.launchApplication(Launcher.java:570) at net.sourceforge.jnlp.Launcher$TgThread.run(Launcher.java:904) Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at net.sourceforge.jnlp.Launcher.launchApplication(Launcher.java:564) ... 1 more Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at com.eteks.sweethome3d.SweetHome3DBootstrap.main(Unknown Source) ... 6 more Caused by: java.lang.ExceptionInInitializerError at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:348 ) at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source) ... 11 more Caused by: com.jogamp.opengl.GLException: Profiles [GL4bc, GL3bc, GL2, GLES1] not available on device null at com.jogamp.opengl.GLProfile.get(GLProfile.java:1039) at com.jogamp.opengl.GLProfile.get(GLProfile.java:1050) at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:803) at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267) ... 18 more Any help getting SH3D to start would be appreciated |
Current timezone is GMT Sep 28, 2026, 11:29:12 AM |
